12-10-2009, 15:06 | #139 (permalink) |
Freak Poster Join Date: Aug 2004 Location: The great pakistan
Member: 79823 Status: Offline Thanks Meter: 26 | => module version: v. => operation (3) started: COM3 ==> get_dll_version dll version: 38.0i ==> set_com_port ==> set_baud_rate ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 354354030243250 ==> get_sw_version sw ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B09 ==> get_sec_version sec ver: 00.323Et(4242) ==> get_eep_version eep version: 0001 ==> get_eep_revision eep revision: 0000 ==> reading... access result: 00 access level: 00 code verification result: 05 access result: 00 access level: 00 This model can not be unlocked yet last error: No errors => operation finished Please, send operation.log file to support Include in your mail phone name and full text from phone back label DO NOT run this test many times, it's enough to read information only once ! ==> close_com_port Finished, time used: 19 sec Power Off/On phone now ! |
The Following User Says Thank You to daanish For This Useful Post: |
12-10-2009, 15:18 | #141 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | http://forum.gsmhosting.com/vbb/showthread.php?t=874885 check here , but this model is not supported yet !! BR Faisal_Computer |
12-12-2009, 15:22 | #142 (permalink) |
Temporary banned !! Join Date: Apr 2007
Member: 482214 Status: Offline Sonork: 100.1617896 Thanks Meter: 316 | ZTE A316G+ NOT UNLOCK => module version: v.1.72PANA01 => operation (3) started: COM6 ==> get_dll_version dll version: 38.0i ==> set_com_port ==> set_baud_rate ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> set_v24_mode ==> check_comm_link ==> get_ms_id imei: 354354030242815 ==> get_sw_version sw ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B09 ==> get_sec_version sec ver: 00.323Et(4242) ==> get_eep_version eep version: 0001 ==> get_eep_revision eep revision: 0000 ==> reading... access result: 00 access level: 00 code verification result: 05 access result: 00 access level: 00 This model can not be unlocked yet last error: No errors => operation finished Please, send operation.log file to support Include in your mail phone name and full text from phone back label DO NOT run this test many times, it's enough to read information only once ! ==> close_com_port Finished, time used: 17 sec Power Off/On phone now ! |
12-13-2009, 08:43 | #143 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Shahdadpur Age: 33
Member: 600482 Status: Offline Thanks Meter: 85 | => module version: v. => operation (3) started: COM4 ==> get_dll_version dll version: 38.0i ==> set_com_port ==> set_baud_rate ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 354354030144938 ==> get_sw_version sw ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B09 ==> get_sec_version sec ver: 00.323Et(4242) ==> get_eep_version eep version: 0001 ==> get_eep_revision eep revision: 0000 ==> reading... access result: 00 access level: 00 code verification result: 05 access result: 00 access level: 00 This model can not be unlocked yet last error: No errors => operation finished Please, send operation.log file to support Include in your mail phone name and full text from phone back label DO NOT run this test many times, it's enough to read information only once ! ==> close_com_port Finished, time used: 10 sec Power Off/On phone now ! |
12-13-2009, 09:16 | #144 (permalink) |
Banned Join Date: Oct 2007 Location: Pakistan
Member: 617666 Status: Offline Sonork: 100.1592356 Thanks Meter: 397 | ZTE A316G+ Not Unlock => module version: v.1.72 => operation (3) started: COM4 ==> get_dll_version dll version: 38.0i ==> set_com_port ==> set_baud_rate ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> set_v24_mode ==> check_comm_link ==> get_ms_id imei: 354354030319308 ==> get_sw_version sw ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B09 ==> get_sec_version sec ver: 00.323Et(4242) ==> get_eep_version eep version: 0001 ==> get_eep_revision eep revision: 0000 ==> reading... access result: 00 access level: 00 code verification result: 05 access result: 00 access level: 00 This model can not be unlocked yet last error: No errors => operation finished Please, send operation.log file to support Include in your mail phone name and full text from phone back label DO NOT run this test many times, it's enough to read information only once ! ==> close_com_port |
The Following User Says Thank You to ASIF JAAn For This Useful Post: |
zong zte a316g+ unlock problem | astana2007 | FuriousGold | 6 | 01-26-2010 09:33 |
Zong zte a316g unlocking erorr | nawaz_ideal | FuriousGold | 0 | 01-06-2010 15:16 |
why Zong ZTE A316G+ not unlock with furious please give solution | sahil00150 | FuriousGold | 1 | 01-06-2010 14:39 |
Zong zte a316g+ unlocked usercode done | yasermalik | SAGEM JTAG UNLOCKER | 1 | 11-24-2009 06:25 |
<<< Zong Zte A316G+ Pinouts Detection >>> | khadim100 | Infinity-Box | 2 | 11-18-2009 16:48 |
