11-17-2017, 12:18
#1 (permalink)
Join Date: May 2013 Location: Hacked by Hackflax on tiktok
Member: 1941705
Thanks Meter: 1,248 | Zopo c2 Zopo C2 Flash Firmware Quote:
Scatter Load Ok , BaseBand : MT6580 , Project : w371 , Storage : EMMC
Files found : 9 , Set to Flash : 8
Ready to Flash!
Operation : Flash [ v1.57 ]
======= Flash
Wait for phone...
Phone found! [ 1265 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 88010345504231303028A2AC2B60236B
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x88 , OEM : 0103
[eMMC] : FLASH_INF : [FORESEE] , 001BP
[eMMC] : FLASH_CID : 88010345504231303028A2AC2B60236B
[eMMC] : FLASH_LEN : 0x00000001CE100000
[eMMC] : FLASH_UCP : 7393 MiB [eMMC 8 GiB]
DEV RID : 0xCD5A1551644B15881E9AFB2FB45CCFCF
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6580 , Project : w371 , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : Unknown (not supported or without battery)
BL : Flash Pre-Erase
Total blocks to Erase : 1
Erase : 0x0000000001C80000-0x00000000F8B80000
Flash Pre-Erase Done, time used : 00:00:02
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_w371.bin
Preloader Sent , Init passed
PartCount : 0014
Update PMT by user request
[SpecOp] : Extend UserArea
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : LK
Image Flash Ok
Flash now : BOOT
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : SECRO
Image Flash Ok
Flash now : SYSTEM
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USERDATA
Image Flash Ok
Flash Write Done, time used : 00:09:15
Processing : Verify
Verify Passed : LK
Verify Passed : BOOT
Verify Passed : RECOVERY
Verify Passed : LOGO
Verify Passed : SECRO
Verify Passed : SYSTEM
Verify Passed : CACHE
Verify Passed : USERDATA
Data Verify Done, time used : 00:00:56
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:10:37
Reconnect Power/Cable! | |
