Old 11-09-2015, 13:19   #1 (permalink)
Member: 322417
Thanks Meter: 940
Question Need Help to identify Phone Model. Thanks
I have HAIER phone with erased preloader. Label under battery is removed.
I cant recognize what kind of model is to download flash file.
On Identify and Read info i got this log.
Any Chance to recognize model from this info ?
Card found : S/N : CB822A50 , v0129
Chinese Miracle II [MTK module] v 1.35
Operation : Check / Read Info [ v1.35 ]
Wait for phone...
Phone found! [ 107 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0xFE
SecCfgVal : 0x00000000
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 110100303034473930104E24AC08A005
DA Stat : v4.2 on BBID : 0x88
DRAM not initialized , configure DRAM Settings
DRAM EmiReq Ok , 0x00A8
DRAM Init Ok , 0x20000000
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0000 , OEM : 0000
[eMMC] : FLASH_INF :
[eMMC] : FLASH_CID : 00000000000000000000000000000000
[eMMC] : FLASH_EXT : 00000000/00000000
[eMMC] : FLASH_LEN : 0x0000000000000000
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Info read not done Erased phone or unsupported FlashIc?
You can change settings : Settings -> Other -> NAND init Mode
Done!
Elapsed: 00:00:13
Reconnect Power/Cable!
Thanks in Advance
Old 11-09-2015, 13:46   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello.
Seems as it completely erased and no any info inside was found.
Old 11-09-2015, 14:05   #3 (permalink)
Member: 322417
Thanks Meter: 940
Originally Posted by JayDi View Post
Hello.
Right,
There is no other way so we can find ?
Trying according to images from Google but no lucky at all
br
Old 11-09-2015, 23:29   #4 (permalink)
Member: 322417
Thanks Meter: 940
I found model but there is no flash file on support. T757 haier. Any one to share?
Sent from my GT-I9506 using Tapatalk
Old 11-12-2015, 01:28   #5 (permalink)
Member: 322417
Thanks Meter: 940
Where is support ?
Strange , infinity was one of best what is happening
Old 11-12-2015, 08:53   #6 (permalink)
JayDi's Avatar
Member: 462970
I phisically can't have all models, which running over world. Need just make request over forum or seek in google for FW.
Old 11-12-2015, 13:58   #7 (permalink)
Member: 322417
Thanks Meter: 940
Understood ,
Its strange problem and the only flash i found didnt work
any way thank you
Page generated in 0.14540 seconds with 9 queries
