10-30-2007, 18:31 | #1 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 364696 Status: Offline Thanks Meter: 16 | Need Help DVD S618 it start like this when we power on, it shows counting 1..100 then gose off when get full info its ok OM3 [VCP0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: NAND reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... chip-id: 0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 NAND: Samsung K9F1G08X0M 2048+64 64 pages, 132Mb NAND id: ECF18015 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00EC:00F100800015 [08400000] warning: NOR flash chip not supported or not detected Initialize Done Set baud... 230400 Set baud Done Identification... converting data... done protocol ver: 04 ver. sw1: SHINEC28_06A_PCB04_GPRS_MT6228_S02.SHINEC_S2_IL922 1_V2_2.BIN ver. sw2: SHINEC_S2_IL9221_V2.2 ffs offset/size: 02000000/06000000 id-page Ok nfi area detection finished: Ok structure: 2nd [enhanced] (or higher) generation identification data Ok identification data backup saved: id.27EADFDB.[SHINEC28_06A_PCB04_GPRS_MT6228_S02.SHINEC_S2_IL922 1_V2_2.BIN_B202C57C].rpl New firmware detected: SHINEC28_06A_PCB04_GPRS_MT6228_S02.SHINEC_S2_IL922 1_V2_2.BIN - make "Read detailed information" operation - send "backup_system_log_..." file to support - make "Read full flash" operation - send flash backup file(s) to support - include in your e-mail full text from phone back label (phone name etc.) identification detection finished Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... Write Done file saved: backup_system_log_27EADFDB_SHINEC28_06A_PCB04_GPRS _MT6228_S02.SHINEC_S2_IL9221_V2_2.BIN_B202C57C_200 71029-103300.B4X.bin Finished, time used: 78 sec Remove/Install battery now ! safe form COM3 [VCP0] selected Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6228:8A02]... Connecting, wait... error: can't finalize test moide Operation failed ! Finished, time used: 21 sec Remove/Install battery now ! it format complete ok after complete formatting phone is in same position but when we get detailes info it gives COM3 [VCP0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... chip-id: 0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 NAND: Samsung K9F1G08X0M 2048+64 64 pages, 132Mb NAND id: ECF18015 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00EC:00F100800015 [08400000] warning: NOR flash chip not supported or not detected Initialize Done Set baud... 230400 Set baud Done Identification... converting data... done protocol ver: 04 ver. sw1: SHINEC28_06A_PCB04_GPRS_MT6228_S02.SHINEC_S2_IL922 1_V2_2.BIN ver. sw2: SHINEC_S2_IL9221_V2.2 ffs offset/size: 02000000/06000000 id-page Ok nfi area detection finished: Ok structure: 2nd [enhanced] (or higher) generation error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: identification data damaged identification detection finished Finished, time used: 263 sec Remove/Install battery now ! now can i flash it |
10-30-2007, 20:14 | #2 (permalink) | |
Yes... I completely agree with you... Let's all together ignore text from software log window ! Can you flash ? Yes... But phone will be dead after flashing. Why ? because everybody ignore text in software log window. | |
11-01-2007, 18:41 | #3 (permalink) |
Member: 364696 Status: Offline Thanks Meter: 16 | sir plz tell me what i do i mean can i flash it if yes then from where i get flash file. i have already send back up files to team support with lable text on phone but team did not respond me. i m waiting for reply and flashfiles. can i flash me phone with backup files thanks team |
11-01-2007, 22:58 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | where you have sent files ? What files exactly was sent ? correct mail for flash files: [email protected] |
11-02-2007, 08:59 | #5 (permalink) |
Member: 364696 Status: Offline Thanks Meter: 16 | sir i have send the following files to ur mail address metioned above SHINEC28_06A_PCB04_GPRS_MT6228_S02.SHINEC_S2_IL922 1_V2_2.BIN backup_system_log_..." file to support - include in your e-mail full text from phone back label (phone name etc.) |
11-02-2007, 09:19 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Yo will be able to flash phone with this firmwae in next Infinity-Box update. Also you can try to use other flash files with firmware version name like SHINEC28..., only firmware version is important criteria, not phone model name. |
FuriousGold & NEW CABLES SET 2010 (UPDATED 30 MARS 2010) NEED HELP | FuriouS TeaM | FuriousGold | 66 | 08-27-2010 13:20 |
need help master manole n95-8gb write screen restart | haslyn | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 15 | 03-30-2010 10:56 |
nokia masters need help.............. | ANILMPLY | Nokia Hardware & Hardware Repair | 0 | 03-29-2010 10:48 |
DVD s618 | Benzee76 | Infinity-Box | 7 | 07-21-2008 23:09 |
Mark Levinson Dvd Player... Need Help! | Saff | CAR Electronics | 0 | 11-27-2007 22:41 |
