Old 08-21-2008, 09:17   #1 (permalink)
JC_BY's Avatar
Member: 59319
Sonork: 100.1606948
Thanks Meter: 82
ZT710 problem with detection
Phone is working but it sometimes LCD is powers off.
I found pinout with PinFinder.
But when I tried to read detailed info it powered on during detection:
COM6 [VCP1] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read/check detailed information
Boot...
19200 fixed
Connecting, wait...
Initializing[6205:8B00]...
CPU: MT6205
high speed boot enabled
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
error: no any expected answer
error: no any expected answer: wrong answer after chip id request
error: no any expected answer: wrong answer after chip cfi request
number of flash chip/regions detected: 00/01
Unknown or damaged flash chip, operation aborted.
Fault reasons:
1. damaged flash chip: replace or resolder/reball flash chip
2. damaged hardware: check hardware, water inside etc.
3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again
4. wrong model selection, try 'NAND' selection
Initialize Fail
Finished, time used: 95 sec
Remove/Install battery now !
Old 08-21-2008, 12:47   #2 (permalink)
Member: 583680
Thanks Meter: 47
Connecting, wait...
CPU: MT6205
Hello,
I think You have detected pinout for CPU2
Exclude these pins in pinfinder and try to find pinout for CPU1
Old 08-21-2008, 15:10   #3 (permalink)
JC_BY's Avatar
Member: 59319
Sonork: 100.1606948
Thanks Meter: 82
Originally Posted by ezzis View Post
Connecting, wait...
CPU: MT6205
Hello,
plese explain how to exlude pinout during detection?
COM6 [VCP4] selected
Boot...
19200 fixed
Connecting, wait...
CPU: MT6205
Boot Done
Initialize...
flash: 01227E221A2201:18E59F00000000
Fault reasons:
Initialize Fail
Finished, time used: 31 sec
Old 08-21-2008, 15:18   #4 (permalink)
JC_BY's Avatar
Member: 59319
Sonork: 100.1606948
Thanks Meter: 82
Connecting, wait...
CPU: MT6205
Hello,
Thank you.
With CPU1 all ok
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:060C:F169
high speed disabled
boot step size: 0002
Boot Done
Initialize...
flash: 01227E22202200:29EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
460800
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.172ABF9B.[MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16.BIN_CA420BC9].rpl
identification#1 detection finished
device-id: 172ABF9B
identification#1 protocol ver: 04
ver. sw1: MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16.BIN
ver. sw2: MAUI.05C.W06.16, 36F4BD35
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
detecting ffs structure pass 1...
detect standard fat location pass #1...
detect extended fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs element #1 detected ok
detecting ffs structure pass 2...
ffs element #2 detected ok
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_172ABF 9B_MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C _W06_16.BIN_CA420BC9_20080821-171705.B0X.bin
Finished, time used: 164 sec
big problem with my mx key sshreesai MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 03-31-2010 10:07
problem with nokia 6234 pachicoo Universalbox 2 03-29-2010 15:19
Problem with detecting products cnapkc Phoenix Black Box 5 02-15-2006 11:54
Problem with detection of 8210 ReZn0r Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-12-2001 12:51
Page generated in 0.17924 seconds with 9 queries
