Old 11-14-2007, 06:50   #1 (permalink)
jothi737's Avatar
Member: 369539
Sonork: 1584109
Thanks Meter: 32
zt8380 error while read flash
view log
COM4 [VCP1] selected
Device: Autodetect 6228 NAND
Checking data, wait...
Action: read NAND flash
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6228:8A02:8A02]...
chip-id: 0000:0101
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
version: 3.1
NAND id: ADF1801D
page size: 800+40
pages/block: 40
bits i/o: 08
address cycles: 04
blocks: 0400
ram size: 00800000
NOR: 0000:000000000000 [00000000]
NAND: 00AD:00F10080001D [08400000]
warning: NOR flash chip not supported or not detected
Initialize Done
Set baud...
115200
Set baud Done
Identification...
reading...
detecting structure...
converting data...
done
protocol ver: 04
ver. sw1: RATECH28_06A_PCB04_GPRS_MT6228_S02.R2000_01_1_6T0H S0822.BIN
ver. sw2: R2000_01_1.6T0HS0822
ffs offset/size: 02000000/06000000
id-page Ok
nfi area detection finished: Ok
structure: 2nd [enhanced] (or higher) generation
error: unexpected answer:
identification data damaged, recalculation required
identification detection finished
reading...
warning: probably errors exist during flash read operation
Finished, time used: 252 sec
Remove/Install battery now !
Old 11-14-2007, 12:06   #2 (permalink)
jothi737's Avatar
Member: 369539
Sonork: 1584109
Thanks Meter: 32
hello infinity help......................
Old 11-14-2007, 17:12   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
try to repeat read operation several times, be sure that connector contacts is clean and battery enough charged.
Old 11-25-2007, 20:05   #4 (permalink)
BAYOO's Avatar
Member: 58608
Sonork: 100.87163
Thanks Meter: 54
Originally Posted by InfinitySupport View Post
Hello,
Hello brother
Sure i try more and several time to read flash file for this phone but cann't i found flash file in support for this Model but also cann't Write flash for phone to change lang for it this phone (have Nand flash ) i try read only Nand backup for phone but also cann't pls brother if u can check this problem . need to told u also we are satisfy with this tool and need from u improved some Option to can get full operation to handel these phones
Thx
BAYOO
Old 11-25-2007, 20:15   #5 (permalink)
Member: 130995
What cable you have used ?
Try to use cable based on FTDI (f.e. Infinity unibox) but not cables based on Prolific chip.
Old 11-26-2007, 11:32   #6 (permalink)
jothi737's Avatar
Member: 369539
Sonork: 1584109
Thanks Meter: 32
FTDI =?
Prolific chip=?
explain pls
Old 11-26-2007, 11:41   #7 (permalink)
.::BHATTI::.'s Avatar
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
FTDI... these are the chips for the faster data rates i.e used in infinty box..
Profilic are the usb to serail cables .. also got soe faster dta rates .. but FTDI is good ... and about ur logs it can be the hardware .. try one more time ...
error while reading flash voda 527 electrolandgsm SMTi 0 01-21-2009 20:45
v980 says at command error while reading info gsmservices Smart-Clip 15 11-27-2007 09:09
Always Error ,While Reading SE flash khawar SonyEricsson (USB-Smart) 1 09-16-2005 08:36
SE T68i Error while modem flashing VanHelsing Twisterflasher 5 11-13-2004 03:13
m55 errase error while its flashing VolcoM E-Gold Based Phones 6 07-07-2004 23:57
Page generated in 0.25134 seconds with 10 queries
