09-05-2008, 00:49 | #1 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Europe, Lemberstadt Age: 53
Member: 9889 Status: Offline Thanks Meter: 50 | ZT999 question i put 2 working sim SIM A find network and show it SIM B find network too but show "Searching" all time i can make call from SIM A and SIM B w/o any pb tried ffs safe and complete format CPU1 change Imei1 and Imei2 but when i enter *#06# i can see only one imei number (is it normally?) and still "Searching" does it mean i need format ffs in CPU2 or something other? need advice Thanx |
09-08-2008, 07:58 | #5 (permalink) | |
Freak Poster Join Date: Jan 2008
Member: 679383 Status: Offline Thanks Meter: 34 | Quote:
09-09-2008, 22:47 | #6 (permalink) |
Member: 9889 Status: Offline Thanks Meter: 50 | i try to read 2nd flash: COM9 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #02 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #03 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #04 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #05 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #06 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #07 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00380000 flash: 01227E221A2201:18E59F00000000 checking area[00000000]: 00000000-003FFFFF... eeprom/ffs found near: 00380000 detecting eeprom/ffs size... eeprom/ffs size: 00080000 ffs chip: 00 eeprom/ffs area: 00000000:00380000-003FFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: flash... warning: wrong data size at 0x00035800, retry... warning: wrong data size at 0x00035800, retry... warning: wrong data size at 0x00035800, retry... warning: wrong data size at 0x00035800, retry... warning: wrong data size at 0x00035800, retry... warning: wrong data size at 0x00035800, retry... warning: wrong data size at 0x00035800, retry... warning: wrong data size at 0x00035800, retry... warning: wrong data size at 0x00035800, retry... error: too many retries during read operation Probably errors exist during flash read operation. Do you want to repeat read operation ? error: wrong answer: 3B Probably errors exist during flash read operation. Do you want to repeat read operation ? error: wrong answer: BB Probably errors exist during flash read operation. Do you want to repeat read operation ? operation canceled by user Finished, time used: 111 sec Remove/Install battery now ! allways errors when i try to read or format 1st flash reads ok is this hardware problem? |
09-12-2008, 06:04 | #10 (permalink) |
Banned Join Date: Jul 2005 Location: Philippines Age: 53
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | @infinity please check COM5 [VSerial0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:32AE:29EE high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 230400 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.B20BF5F8.[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B58.BIN_E C7BB556].rpl identification#1 detection finished device-id: B20BF5F8 identification#1 protocol ver: 04 ver. sw1: U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B58.BIN ver. sw2: UPU25U26V03B58, A94A8413 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:2AEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B58.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\ZT999\eeprom[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B58.BIN]_20080912-124853.B0E.bin flash: EC257E25082501:2AEA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished security area#1 calculation... done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_B20BF5F8_U26_06B_PCB01_GPRS_MT6226_S01.U PU25U26V03B58.BIN_EC7BB556_20080912-125133.B0X.bin Area: Firmware flash: EC257E25082501:2AEA0000000000 Write: Firmware error: no any expected answer error: flash write error: 00008000:00002000 error: error# 000000FF error: flash write error: 00008000:00002000 error: no any expected answer error: flash write error: 00008000:00002000 error: no any expected answer error: flash write error: 00008000:00002000 error: no any expected answer error: flash write error: 00008000:00002000 |
09-12-2008, 06:10 | #11 (permalink) | |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | Quote:
br | |
09-14-2008, 04:53 | #15 (permalink) | |
Keyboard Top CPU1 6226 /1 2 3 4 5 6\ 7 8 9 10 11 12 6 : GND 5 : RX 3 : TX CPU2 6205 6 : GND ? : ?? ? : ?? Last edited by djiphone76; 09-14-2008 at 05:02. | |
Question regarding credits [ANSWERED] | ravikumar.boddu | PolarBox 3 | 3 | 03-29-2010 15:19 |
zt999 | narshipatel | Chinese Models & Cloned Phones | 0 | 06-21-2008 20:23 |
ZT999 camera module not ready | sundar83 | Infinity-Box | 6 | 05-30-2008 05:57 |
Backup for N99i & ZT999 ??? | Rana Bose | Chinese Cocktail | 0 | 01-17-2008 07:42 |
ztc zt999 - nokla n78 | imanpanahi | Infinity-Box | 2 | 09-11-2007 07:00 |
