Old 11-06-2009, 10:09   #1 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
ztc 8089 dead i need firmware
what should i do this
COM12 [VCP0] selected
module v2.84
Action: reset settings
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing [6223:8A04:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:CDDC:000C
status: FF
Connecting at 19200, wait...
warning: wrong packet cs
Release Power button now !
Phone detected, wait...
warning: can't read software version, probably unknown firmware
detecting structure #2...
0 1warning: wrong packet cs
2 3warning: wrong packet cs
4warning: wrong packet cs
5warning: wrong packet cs
6warning: wrong packet cs
7warning: wrong packet cs
8warning: wrong packet cs
9warning: wrong packet cs
10warning: wrong packet cs
11warning: wrong packet cs
12warning: wrong packet cs
13warning: wrong packet cs
14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29error: detection failed (30 tries), read flash and send to support
connection Ok
building list...
done
no items found
error: operation failed !
Finished, time used: 172 sec
Remove/Install battery now !
Old 11-06-2009, 10:13   #2 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
module v2.84
19200 autodetect
CPU: MT6223
high speed boot On
status: FF
connection Ok
building list...
done
no items found
but as far as i see now u have comminication pb.. which cable r u using..?
Old 11-06-2009, 10:14   #3 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
module v2.84
19200 autodetect
CPU: MT6223
high speed boot On
status: FF
connection Ok
building list...
done
no items found
and u r working now with second cpu.. (6223 cpu)..
Old 11-06-2009, 10:24   #4 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
pleas any one can give me firmware for this phone ztc8089
CPU MT6223 THANK YOU
Old 11-06-2009, 10:26   #5 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
module v2.84
Device: Autodetect 6205-6227 NOR
Action: "format ffs"
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
boot packet size: 0400
Boot Done
Initialize ...
flash: 2AEA00F098E59F:2AEA0000000000
number of flash chip/regions detected: 00/01
flash chip is unknown or damaged, operation aborted.
Fault reasons:
1. flash chip is damaged: replace or resolder/reball flash chip
2. hardware is damaged: check hardware, water inside etc.
3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again
4. wrong model selection, try 'NAND' selection
Initialize Fail
Finished, time used: 15 sec
Old 11-06-2009, 10:29   #6 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
6223 is the first CPU..?
Old 11-06-2009, 13:16   #7 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
yes is the first cpu type infinity team i need this firware eeprom cause my phone is totally dead
Old 11-06-2009, 13:41   #8 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
what was the phone codition..? and check the ur log.txt file for details...
Old 11-07-2009, 02:02   #9 (permalink)
Member: 130995
Thanks Meter: 35,227
module v2.84
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
Boot Done
Initialize ...
Fault reasons:
Initialize Fail
Hello,
At first you need to open phone and check it's hardware.
Did you tried to check phone hardware ?
What is the results ?
Old 11-07-2009, 02:57   #10 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
Hello,
Report Post Reply With Quote
ser this phone is not dead before the problem is when you insert simcard the phone is hung up but when you not inserted sim card the phone is okay i try using format but the phone is totally dead i have no back up this phone pleas sir i need firmware this phoe and eeprom thank you
Old 11-07-2009, 10:03   #11 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
u havent any eeprom file..? and did u try repair scurtiy area...?
Old 11-07-2009, 10:54   #12 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
all that i try and the problem is firmware
Old 11-07-2009, 10:56   #13 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
bu i see in the support area have no file firmware that mobile so i need help from infinity support team
Old 11-08-2009, 21:05   #14 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
first of all disassemble phone and resolder or heat flash ICs.
after that you will be able to read out current software version.
only after this you can search support area for flash file.
need firmware ajit bs Infinity-Box 1 03-30-2010 05:05
need firmware for ztc zt6698 peter002 Infinity-Box 2 04-25-2008 15:58
need hlp for the pinouts of ztc zt6698 dead.. plz hlp peter002 Infinity-Box 4 04-24-2008 15:18
need firmware for a dead SE T290i reactos Sony Ericsson Hardware Repair 0 05-24-2007 11:08
Page generated in 0.26291 seconds with 9 queries
