02-23-2008, 08:15 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: KOLHAPUR, MAHARASTRA,INDIA
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | Ztc 8898 Chinese Phone Need Pinouts |
02-23-2008, 08:34 | #2 (permalink) |
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | Ztc 8898 Chinese Phone Need Pinouts ZTC 8898 Pinouts Needed . Chinese Phone Looks Like E90 Nokia. Can Any One Post Pinouts Thank In Advance.connector Type 1x20. |
02-23-2008, 09:01 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Dear Friend, Currently many "Chinese" models with the same name but absolutely different hardware exist on market. Exmple: exist at least 20 phones with name "Chinese Nokia-N95" but all models has difference in hardware, different bottom connectors, different pinouts and and has different firmware, so we recommend you to include the next information in your request regarding pinout: 1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, you can find pinout by yourself more easy than before, just check the next detailed description how to get pinout for your model: 1. use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ 3. if not helps, please read: http:///vbb/showpo...36&postcount=7 4. if not helps, please read: http:///vbb/showthread.php?t=433447 |
02-26-2008, 13:03 | #6 (permalink) |
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | pinout ztc 8898 i look same model in market different name nocla e90 , same body ,fuction, pinout,cpu but brand other name not match rx 13 tx14 any other solution |
02-27-2008, 17:25 | #7 (permalink) |
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | error rx 13 tx 14 COM3 [VCP1] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: boot initialization step-2 failed: 00 9600 error: boot phase#2/1 failed Can't initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. eeprom/ffs serious damaged, use repair eeprom/ffs files or use other unlock/format method error: operation failed ! Finished, time used: 25 sec Remove/Install battery now ! |
03-08-2008, 14:31 | #11 (permalink) |
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | Confuse Find Rx Tx In New Cpu China Model To System Conn. So Many Pins Voltage Are Same Between 2.5v To 3v This The Big Confusen whice is The Best Idea Select Rx & Tx Pins Any new Other good and simple Method |
03-08-2008, 21:22 | #12 (permalink) | |
We have released new hardware with new cables for automatic pinout detection: http://www.infinity-box.biz/index.ph...infinder&lg=en | |
03-14-2008, 10:15 | #13 (permalink) |
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | find rx & tx but new cpu support i find rx & tx manually but infinity support new cpu ,they are some error i send cpu photo Last edited by omkarvitekar; 03-14-2008 at 10:22. |
1600 China phone need pinout | kasamiko | Infinity-Box | 3 | 05-09-2009 11:22 |
chinese phone M660 pinouts needed | azeem781986 | Chinese Models & Cloned Phones | 1 | 11-03-2008 14:53 |
ztc zt6698 and zt6618 need pinouts | MANDEEP80104 | Infinity-Box | 3 | 04-08-2008 17:21 |
Ztc 8898 Pinouts Needed | amit_varietymob | Various | 2 | 03-08-2008 14:18 |
Sir I Need Ztc H668 China Phone Pinouts | sulai2k | Infinity-Box | 2 | 02-21-2008 11:50 |
