Ztc C2000/cect C1000 & Pinout Finder Dear Infinity support; I just got my pinfinder and i'm quite satisfied with the function.About MTK cpus all is ok but models like cect c1000 and ztc c2000 have cpus other than MTK,are they supported?Do i have to use L18A cable? They have Spreadtrum CPUs as far as i know,is it right?then every info would be appreciated. Thanks in advance. |
Which CPU model shall i select exactly for Spreadtrum models? |
Hello, Spreadtrum CPU is not supported yet by PinFinder, will be supported in nearest days. |
Oi u muste open the phone keyboard up juste up of connector there is tow piont -rx and tx u can peut gnd any where wbr |
Is it supported by Infinity soft and not developed for Pinfinder? Anyway hope to make it work like other things you've made.Which cable shall i use for them? |
Infinity as yet doesnot support Spreadtrum CPU. |
hello! pinout search for CPU tpe: Spreadtrum is added in pinout findr version 1.06 Which cable to use: that cable which will fit to your spreadtrum phone connector. |
I just don't know how to appreciate your nice great hard work,may *** help you get more and more of success. |
hello! best way to say "thank you" is test report if anyone have speadtrum phones on hands, please try our new feature |
new feature? what thats mean br?cause i have one speadtrum cpu phone thx |
hello! this means that using pinout finder you can find pinout for your Spreadtrum phone |
oi i have now ztc c2OOO on the hand but no succes with auto pinout finder juste resolder on the pcb when i sgec with pinout on pcb and the connecter i found good relation between them i set manly on the pinout finder but no succes too |
Hello, Probably you need to swap Rx/Tx. |
wbr |
hello! did i undertoode you right: you have a phone with spreadtrum MCU. pinout finder failed to find pinout for it but phone have marked test points with "tx", "rx" lables and they are linked to two pins in system connector? please correct me if i am wrong |
