Old 04-15-2008, 15:23   #1 (permalink)
vinay_sharma's Avatar
Member: 309398
Sonork: 100.1590052
Thanks Meter: 5,455
Thumbs up Vodafone 125 unlocked successfully
COM3 [VCP0] selected
Device: Vodafone 226
Checking data, wait...
Action: unlock
unlock method-1
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
middle part...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud...
115200
Set Baud Done
Connecting...
flash: 0001:011A
Connecting Done
Check hardware...
flash chip supported
sw version: EBI_II EBI_II_060807_1127 060807_1127 Thhmm Dddmmmyyyy 01234567
Check hardware Done
Check parameters...
Check parameters Done
backup critical area...
reading [eeprom-sta]...
file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080415-193226.B1E.bin
loading data...
wrong database file: C:\Program Files\InfinityBox\Pana01\z225_eep65535.cfg
error: can't load database v.14
reading [eeprom-sec]...
file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_20080415-193230.B1E.bin
reading [eeprom-complete]...
file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_20080415-193236.B1E.bin
reading additional data...
done
backup critical area Done
Check memory...
current status: 0
Check memory Done
Write...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, Remove/Install battery now !
Time used: 45 sec
Unlock instruction:
1. Power-On phone
2. Enter code: 12345678
Old 04-15-2008, 15:27   #2 (permalink)
Member: 309398
Sonork: 100.1590052
Thanks Meter: 5,455
Mistake
Vodafone 226 unlocked successfully
Old 04-15-2008, 19:31   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Thank you very much for good test report !
Old 04-16-2008, 16:25   #4 (permalink)
Member: 48366
Thanks Meter: 30
Originally Posted by InfinitySupport View Post
Hello,
Hello friend
I tried to unlock ZTE 125, successfully unlocked but the phone still locked.
Tried full flash from the support and write eeprom, but still the phone is locked.
What would be the best solution for the phone?
Thanks and best regards,
Jham
Old 04-16-2008, 17:19   #5 (permalink)
Member: 130995
Originally Posted by jham View Post
Hello friend
Jham
Hello,
It's impossible to unlock phones with blocked unlock counters.
Old 04-16-2008, 18:05   #6 (permalink)
moez.mobileline's Avatar
Member: 202820
Thanks Meter: 11
Hello,
hello plz solotion i have zte sim bloked
i wainting solotion
Old 04-16-2008, 18:19   #7 (permalink)
Member: 130995
i wainting solotion
Hello,
Old 04-16-2008, 18:21   #8 (permalink)
Member: 202820
Thanks Meter: 11
Hello,
no friend jitag unlok the model
Old 04-16-2008, 18:23   #9 (permalink)
Member: 130995
Hello,
It's impossible to unlock phones with blocked unlock counters with Infinity-Box.
If you want to talk about something other you are in wrong forum section and you must make posts in another forum section.
Old 04-16-2008, 19:24   #10 (permalink)
damabib's Avatar
Member: 106026
Sonork: 100.77890
Thanks Meter: 127
infinity ur solution is verry great...more power 2u ohhh...
Old 04-17-2008, 10:59   #11 (permalink)
Member: 727621
The best box i have ever worked with,years of updates and am still using it no $$$$$ problems with infinity.
Old 04-19-2008, 11:34   #12 (permalink)
Member: 107306
Thanks Meter: 2
I Need A Little Breif!!!
Hello,
WHAT DO U MEAN IT'S IMPOSSIBLE!! WHAT IS HAPPENING TO THE THIS HAND SET WITH BLOCKED COUNTERS?
Old 04-19-2008, 12:46   #13 (permalink)
Member: 130995
Hello,
This means that it's impossible to unlock phones with blocked unlock counters with Infinity-Box.
Handsets with blocked unlock counters become still blocked.
ZTE 125 / Vodafone 125 Unlock problem sirbigman FuriousGold 4 02-27-2010 14:28
Vodafon 125 unlock code ahmetif Phone Unlocking Codes & Maps 5 11-14-2009 01:13
>>> Dead Vodafone 125 Recvered successfully <<< zeel_zeel Infinity-Box 2 12-13-2008 09:54
Vodafone 125 unlock ..::Sunil::.. Infinity-Box 27 10-19-2008 13:34
*** Vodafone 125 unlocked successfully *** ..::: Naveed :::.. Infinity-Box 3 05-01-2008 08:00
Page generated in 0.33724 seconds with 10 queries
