Old 10-29-2008, 13:39   #1 (permalink)
ericnite101's Avatar
Member: 450871
Sonork: 100.1592197
Thanks Meter: 121
ZTC Q2280 Flash file needed urgent
The phone was perfectly working. I wanted to write Chinese firmware which i got from support area. Then after flash the phone powers on but no display. It only gives white screen.
Here is the original flash file :- flash[HEXING25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12_11.BIN]_20081029-010901.B0M
Please help me its urgent. Thanks in advance.
Old 10-29-2008, 13:45   #2 (permalink)
Member: 450871
Sonork: 100.1592197
Thanks Meter: 121
ZTC Q2280 flash file needed urgent
Here is operation log:-
COM2 [Serial1] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:8003:0007
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 98004900000002:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: MT6225_GEMINI_PCB01_GPRS_MT6225_S00.M6225_00J6_HTC 1_00_V04.BIN
ver. sw2: M6225_00J6_HTC1_00_v04, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading: eeprom[MT6225_GEMINI_PCB01_GPRS_MT6225_S00.M6225_00J6_HTC 1_00_V04.BIN]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[MT6225_GEMINI_PCB01_GPRS_MT6225_S00.M6225_00J6_HTC 1_00_V04.BIN]_20081029-033256.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
detecting security area (code #2)...
security area (code #2) is absent
Area: Firmware
Write: Firmware
Write Done
Finalization...
Finalization Done
Finished, time used: 1930 sec
Remove/Install battery now !
Old 10-29-2008, 20:48   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
What was the reason to flash phone that was not damaged ?
Do you have original flash backup ?
Old 10-30-2008, 08:28   #4 (permalink)
Member: 450871
Sonork: 100.1592197
Thanks Meter: 121
Originally Posted by InfinitySupport View Post
Hello,
The reason of flashing the phone was to get Chinese language course original firmware had no Chinese language. But the phone was working fine. I don't have original flash backup. Please if you can upload this file in support area :-
Old 10-30-2008, 15:45   #5 (permalink)
Member: 450871
Sonork: 100.1592197
Thanks Meter: 121
Anybody can upload this file please?
Old 10-31-2008, 11:14   #6 (permalink)
Member: 450871
Sonork: 100.1592197
Thanks Meter: 121
Hello,
Please help me out InfinitySupport. The phone is now working but doesn't display.
Old 10-31-2008, 20:50   #7 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
solution is simple, but we dont have this flash file.
you must find good working phone with firmware:
read it out and use it for restoring your phone
Old 11-11-2008, 05:33   #8 (permalink)
Member: 450871
Sonork: 100.1592197
Thanks Meter: 121
hello!
I tried my best looking for same kinda a phone so I can read flash file, I couldn't get one. Am waiting for Infinity to upload it in support area. Thanks in advance.
Old 11-11-2008, 19:47   #9 (permalink)
Member: 130995
Hello,
It will be good if somebody can read full flash from the same good working phone and send
full flash backup to [email protected] so we will be able to prepare and upload
good working files in support area for all users.
help ztc-e99 flash file needed rkinfo_imran Infinity-Box 2 09-20-2009 14:32
Ztc zt699 flash file need urgent nakshatra Chinese Models & Cloned Phones 0 07-15-2009 21:00
ZTC ZT926 Flash File needed zeerik SpiderMan 1 02-12-2009 18:36
ZTC ZT926 Flash File needed zeerik Infinity-Box 2 02-11-2009 23:25
ztc-398 flash file need rajesh_ch Infinity-Box 2 08-26-2008 07:00
Page generated in 0.21555 seconds with 10 queries
