ZTC S888 pinouts needed hi ZTC S888 pinouts needed. thanks/. |
Dear Friend, Currently many "Chinese" models with the same name but absolutely different hardware exist on market. Exmple: exist at least 20 phones with name "Chinese Nokia-N95" but all models inside has difference in hardware, different bottom connectors, different pinouts and and has different firmware so we recommend you to include the next information in your request regarding pinout: 1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, you can find pinout by yourself more easy than before, just check the next detailed description how to get pinout for your model: 1. use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ 3. if not helps, please read: http:///vbb/showpo...36&postcount=7 4. if not helps, please read: http:///vbb/showthread.php?t=433447 |
Ztc S888 china 1 Attachment(s) ZTC S888 pinouts needed |
hello! still cant see connector type and where is located GND pins. also: it looks like it has marked test points on PCB. can you make better resolution photo? i will advice which pins to use |
need ZTC s888 pinout. |
hello guys! pinout is printed on PCB. |
