11-22-2007, 04:15 | #1 (permalink) |
No Life Poster Join Date: Sep 2004 Age: 47
Member: 84128 Status: Offline Thanks Meter: 110 | c92 pinout |
11-22-2007, 15:35 | #4 (permalink) |
Member: 84128 Status: Offline Thanks Meter: 110 | the phone name is c92 the connecter is same as samsung d800 20 pin 3 7 and 19 pin are ground.pin 13 and 12 are working only with power on phone i cant make format ffs with this pinout and here is the log Do you want to continue ? COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 11 sec Remove/Install battery now ! |
11-22-2007, 17:57 | #5 (permalink) | |
Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to include the next info: 1. detailed description of model 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 | |
01-22-2008, 22:03 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello ali_imran! 20 pin connector? Run shell.exe, select model "ZTC" > "ZT199" you will find pinout and instruction what to do with phone to get stable connection (disconnect skyworks module) |
01-23-2008, 07:46 | #10 (permalink) |
No Life Poster Join Date: Apr 2007 Location: India
Member: 481609 Status: Offline Sonork: 100.1659889 Thanks Meter: 367 | plz help me infinity team no body know how to solve it and wht mean of resistance 1 k ohms and witch pin is VPP in rj 45 ?its a realy work ? |
01-23-2008, 21:43 | #13 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello ali_imran! you can add this pull_up resistor, VPP is pin 1 of RJ45. but it must work without it also. my advice is to change with places tx and rx wires and try to boot phone again. |
02-09-2008, 14:02 | #14 (permalink) |
Crazy Poster Join Date: Mar 2005 Age: 60
Member: 123372 Status: Offline Thanks Meter: 1 | ALL INFO FROM ME 1. PORT FOR FLASHING AND TEST IS THE ONE 2. BOOTING PROBLEM - IS PROBLEM OF SKYWORKS MODULE. DISASSEMBLE KEYBOARD AND DO WHAT U WANT/ COM6 [VCP5] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031FD7:7607 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: MAUI.05C.W06.16.MP.V28 Version: TELSDA26_05C_HW detecting structure #2... done 60 byte(s) read imei: 35835220070124 connection Ok building list... done items to clear: 205 130 of 205 items cleared 0 items remains Finished, time used: 370 sec Remove/Install battery now ! ALL IS WORKING/ br from BELARUS |
Need Maximus C92 pinout | somratjisan | Chinese Models & Cloned Phones | 0 | 04-09-2009 13:10 |
Need Maximus C92 pinout | somratjisan | Infinity-Box | 0 | 04-09-2009 13:06 |
Need Maximus C92 pinout | somratjisan | CPF-Dongle | 0 | 04-09-2009 13:02 |
Need Bluetooth C92 Pinout | shailesh_chauha | Chinese Cocktail | 9 | 04-21-2008 11:36 |
Need Bluetooth C92 Pinout | amir2202 | Various | 3 | 03-26-2008 18:43 |
