03-14-2008, 16:56 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! first of all open phone and make sure that it is based on MT62xx MCU. also look arround for marked test points on PCB. if there is no any test points, and MCU is supported- post here connector type, we will try to help |
06-19-2008, 13:58 | #4 (permalink) |
No Life Poster Join Date: Jan 2007 Location: mumbai india
Member: 432679 Status: Offline Thanks Meter: 118 | today i tried their on the pcb rx and tx is mentioned clearly...but phone unable to attach with infinity... this cell was ok suddenly became dead,this is dual sim with tv cell model is ZTC TV88... image is attached |
06-19-2008, 14:20 | #5 (permalink) |
Member: 432679 Status: Offline Thanks Meter: 118 | HERE IS THE CPU AND FLASH IC DETAIL cpu ic no1 MT6225A 0743-AGSL ITGW0385[/B] flash ic no1 spansion 71pl127nbohfw4u 750xvm83 L KOREA 06 SPANSION cpu ic no2 MT6205BA 0726-ENSL AJ7F9 flash ic no2 spansion 71GLO16A-40BFWIG 742VVK41 E CHINA 05 SPANION. ONE MORE IC IS THEIR ON PCB I DODNT KNOW FOR WHAT IT IS HERE IS THE DETAIL MT6318A 0721-DYSL MP109 INFI TEAM KINDLY DO THE BNEED FULL. REGARDS! |
07-14-2008, 14:38 | #7 (permalink) |
Member: 432679 Status: Offline Thanks Meter: 118 | thanks zoro ur cable info was right...since afternoon i Was trying cable L10B....NOW its ABLE TO DETECT THE RX AND TX WITH L10C.. kindly tell me how i use this pinfinder to detect second cpu which is MT6205AB. THE FIRST CPU WAS MT6225 WHICH I FORMAT EASILY REGARDS! |
07-14-2008, 14:58 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Go to "More..." PinFiner menu, disable pinout that you already found and try to detect pinout again. |
07-14-2008, 15:19 | #9 (permalink) |
Member: 432679 Status: Offline Thanks Meter: 118 | in more optin ...pinfinder menu.... i disable 7RX and 1TX then also pin finder failed to detect pins. kindly assit ..............or should i open th phone and directly solder the rx and tx for second cpu. regards!............... |
07-14-2008, 15:47 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | It may be that you need to open phone, find POWER_B test point, connect POWER_B to Gnd and repeat 2nd CPU detection process. |
ineed pinuot ztc tv88 | tornado2008 | Infinity-Box | 5 | 01-20-2009 04:59 |
ztc zt9198 and ztc zt918 pinout diferent? | dimitron | Infinity-Box | 2 | 01-20-2008 10:11 |
ZTC IP9300 pinout hr. | gokul2005 | Infinity-Box | 1 | 09-21-2007 17:03 |
I need ZTC-760 pinout ...... | matin-gsm | Infinity-Box | 4 | 09-18-2007 16:38 |
ztc p9200 pinout | raffazila | Various | 0 | 09-05-2007 20:43 |
