ZTC ZT-199 need pinout. Hi! nedd pinout for ZTC ZT-199. Thanks! |
hello! please post connector type to make other users easyer to help you |
1 Attachment(s) I attach a photo of the connector. |
hello! unfortunatly we dont have pinout for this phone in our database. you can try to find pinout by yourself or maybe some of our forum member will help you |
hello! unfortunatly we dont have pinout for this phone in our database. you can try to find pinout by yourself or maybe some of our forum member will help you ----------------- OK! Thanks! |
Hello, Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to make detailed description of model, attach phone photo, phone bottom connector photo and information about Gnd and Charge pins on phone bottom connector. After you have this information prepared, please, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
1 Attachment(s) How to flash ZT-199: 1.Disassemble the phone. 2.Disconnect SkyWorks module under keyboard (Necessarily). 3.Connect RX,TX,GND (view attach) 4.Flash on any boot and flash speed. Sorry for my English! |
br |
how to format a203 how to format a203 . i have problem .if i format the phone their is a error message what should i do pls help |
which SkyWorks module Disconnect SkyWorks module under keyboard (Necessarily). which one is skyworks module . if u have photo pls send to thread |
I now do not have this phone and consequently cannot send you a photo. At the left (if to look from above) there is a white socket under the keyboard, here it and disconnect. |
@kasim "SkyWorks module" is a PCB with big black chip named like "SkyWorks..." |
1 Attachment(s) here is pic when skyworks module is removed :D :D A203 well supported by infinity ;) :) |
Yes , is work True When i remove skywork pcb I can read, format ,and flash is easy :D :D :D :D |
Don't you think that it's good idea to respect Infinity-Box users and supporters for their work ? Please, think with brain (if exist) next time when you write/attach pictures. |
