Old 10-01-2007, 18:46   #1 (permalink)
Member: 469015
Question ZTC ZT-199 need pinout.
Hi! nedd pinout for ZTC ZT-199. Thanks!
Old 10-01-2007, 21:09   #2 (permalink)
Member: 148515
Thanks Meter: 13,684
hello!
please post connector type to make other users easyer to help you
Old 10-02-2007, 11:38   #3 (permalink)
Member: 469015
I attach a photo of the connector.
Old 10-02-2007, 21:54   #4 (permalink)
Member: 148515
hello!
unfortunatly we dont have pinout for this phone in our database.
you can try to find pinout by yourself or maybe some of our forum member will help you
Old 10-03-2007, 09:37   #5 (permalink)
Member: 469015
hello!
OK! Thanks!
Old 10-04-2007, 01:29   #6 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,071
Hello,
Due to a lot of different models with the same name but absolutely different hardware,
bottom connectors and different pinouts we recommend you to make detailed description of model,
attach phone photo, phone bottom connector photo and information about Gnd and Charge pins on phone bottom connector.
After you have this information prepared, please, check the next detailed description how to get pinout for your model:
use "Cable Selector": "Cable selector" at your service...
if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt
if not helps, please read: http:///vbb/showpo...36&postcount=7
if not helps, please read: http:///vbb/showthread.php?t=433447
Old 10-07-2007, 12:16   #7 (permalink)
Member: 469015
How to flash ZT-199:
1.Disassemble the phone.
2.Disconnect SkyWorks module under keyboard (Necessarily).
3.Connect RX,TX,GND (view attach)
4.Flash on any boot and flash speed.
Sorry for my English!
The Following User Says Thank You to n3gr0 For This Useful Post:
Old 10-08-2007, 01:59   #8 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 146
thank u man, i have repaired a sands a203 with this pinout
br
Old 10-08-2007, 08:24   #9 (permalink)
kasim's Avatar
Member: 107448
Thanks Meter: 27
how to format a203
how to format a203 . i have problem .if i format the phone their is a error message what should i do pls help
Old 10-08-2007, 08:30   #10 (permalink)
kasim's Avatar
Member: 107448
Thanks Meter: 27
which SkyWorks module
Disconnect SkyWorks module under keyboard (Necessarily). which one is skyworks module . if u have photo pls send to thread
Old 10-08-2007, 08:59   #11 (permalink)
Member: 469015
I now do not have this phone and consequently cannot send you a photo. At the left (if to look from above) there is a white socket under the keyboard, here it and disconnect.
Old 10-08-2007, 11:09   #12 (permalink)
Member: 130995
@kasim
"SkyWorks module" is a PCB with big black chip named like "SkyWorks..."
Old 10-26-2007, 21:50   #13 (permalink)
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 953
here is pic when skyworks module is removed
A203 well supported by infinity
The Following User Says Thank You to BouRRi_GSM For This Useful Post:
Old 11-19-2007, 18:17   #14 (permalink)
Member: 106455
Thanks Meter: 3
Yes , is work True When i remove skywork pcb I can read, format ,and flash is easy
Old 11-19-2007, 19:11   #15 (permalink)
Member: 130995
Don't you think that it's good idea to respect Infinity-Box users and supporters for their work ?
Please, think with brain (if exist) next time when you write/attach pictures.
ZT-6618 need pinout farhanali Infinity-Box 4 09-30-2008 21:41
Ztc X668 I Need Pinouts N E One Can Help Me ikkks Infinity-Box 3 08-11-2008 20:42
ZTC zt af 320 pinouts sekharv Infinity-Box 1 04-11-2008 12:28
ZTC ZT-199 Diamond.Help romarrio Infinity-Box 1 02-10-2008 00:22
ZTC ZT-199 need pinout help me farhanali Infinity-Box 9 11-12-2007 07:26
Page generated in 0.45800 seconds with 9 queries
