ZTC ZT 8380 not supported... ZTC ZT 8380 dual slim. slide by side youch screen phone... rx, tx, gnd mentioned on pcb only but not suppported for format or aother operation Here is log COM31 [VCP0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: read NAND flash Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... chip-id: 0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 NAND id: ADF1801D page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:00F10080001D [08400000] warning: NOR flash chip not supported or not detected Initialize Done Set baud... 115200 Set baud Done Identification... converting data... done protocol ver: 04 ver. sw1: RATECH28_06A_PCB04_GPRS_MT6228_S02.R2000_ML_01_1_0 T02S0824.BIN ver. sw2: R2000_ML_01_1.0T02S0824 ffs offset/size: 02000000/06000000 id-page Ok nfi area detection finished: Ok structure: 2nd [enhanced] (or higher) generation identification data Ok identification data backup saved: id.27EADFDB.[RATECH28_06A_PCB04_GPRS_MT6228_S02.R2000_ML_01_1_0 T02S0824.BIN_753873DE].rpl New firmware detected: RATECH28_06A_PCB04_GPRS_MT6228_S02.R2000_ML_01_1_0 T02S0824.BIN - make "Read detailed information" operation - send "backup_system_log_..." file to support - make "Read full flash" operation - send flash backup file(s) to support - include in your e-mail full text from phone back label (phone name etc.) identification detection finished WHILE read full flash it gives error... COM31 [VCP0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: read NAND flash Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... chip-id: 0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 NAND id: ADF1801D page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:00F10080001D [08400000] warning: NOR flash chip not supported or not detected Initialize Done Set baud... 115200 Set baud Done Identification... converting data... done protocol ver: 04 ver. sw1: RATECH28_06A_PCB04_GPRS_MT6228_S02.R2000_ML_01_1_0 T02S0824.BIN ver. sw2: R2000_ML_01_1.0T02S0824 ffs offset/size: 02000000/06000000 id-page Ok nfi area detection finished: Ok structure: 2nd [enhanced] (or higher) generation error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: E0 error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: identification data damaged, recalculation required identification detection finished error: unexpected answer: warning: probably errors exist during flash read operation Finished, time used: 200 sec Remove/Install battery now ! Any solutions please. thanks. |
Hello, Please, try to repeat flash rea doperation several times. Also, try to disconnect and connect box again and reboot PC, this may helps. Also, if you have any created "backup_system_log..." files with name loke "RATECH28_06A_PCB04_GPRS_MT6228_S02.R2000_ML_01_1_ 0 T02S0824" please, send it to [email protected] Waiting for yor results. |
Tried everything but same was happened. Noe the Phone is back with cusomer. the said backup_system lig file has been send to yr mail. thanks for prompt reply |
Any news about ZT 8380 support or success anybody please. |
@ infinity support what happens next...after sending log file no reply. please help. ZT 8380 will be supported or not..? thanks. |
ready support. check flash in support area |
Thanks but it refuse to format ffs. |
Flash file downloaded from support using latest chin. miracle 2.05 still error while flashing...please help Loading data, wait... S/N: 13F2:010C Wait... Device: Autodetect 6205-6227 NOR Done Loading file v.02... ZTC-ZT8380_SZMI26_05C_ZHONGYING_PCB01_GPRS_MT6226_S01[1].SZMI26_05C_W0624_M300TS_V1_0_16m_En_Cn_Cn.B0M.bin loaded identification#1 protocol ver: 04 ver. sw1: SZMI26_05C_ZHONGYING_PCB01_GPRS_MT6226_S01.SZMI26_ 05C_W0624_M300TS_V1_0.BIN ver. sw2: SZMI26_05C_W0624_M300TS_V1.0 You have loaded file with security features enabled. Languages: En Cn Cn COM3 [VCP0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: write NAND flash write: Firmware skip: Customization skip: Language Pack skip: Eeprom warning: incorrect bootloader header error: unknown source file structure |
Hello, Exist different ZTC-ZT8380 phones: with MT6226 and with MT6228 CPU. Your phone was with MT6228 CPU but you try to load file for MT6226 CPU and software can't use MT6226 file for MT6228 phone flashing ! |
Thanks for yr attention. Is there flash file exist for cpu MT6228 please. |
Hello, support area -> \flashfiles\ChineseMiracle\_MT6228\RATECH28_06A_PC B04_GPRS_MT6228_S02.R2000_ML_01_1_0T02S0824__ZTC-ZT8380_128m_En_Fr_Vn_Ru_Ar_Th.B4M.bin |
Thanks for support, file downloaded and flashed but still error.. the logs are here... any advise please..... COM3 [VCP0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: write NAND flash write: Firmware skip: Customization skip: Language Pack skip: Eeprom identification#1 protocol ver: 04 ver. sw1: RATECH28_06A_PCB04_GPRS_MT6228_S02.R2000_ML_01_1_0 T02S0824.BIN ver. sw2: R2000_ML_01_1.0T02S0824 ffs offset/size: 02000000/06000000 id-page Ok nfi area detection finished: Ok Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... chip: 0031:0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 NAND id: ADF1801D page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:00F10080001D [08400000] NOR chip is not installed Initialize Done Set baud... 115200 Set baud Done Identification... reading... detecting structure... converting data... done 0x00080000 bytes identification#1 protocol ver: 04 ver. sw1: RATECH28_06A_PCB04_GPRS_MT6228_S02.R2000_ML_01_1_0 T02S0824.BIN ver. sw2: R2000_ML_01_1.0T02S0824 ffs offset/size: 02000000/06000000 id-page Ok nfi area detection finished: Ok identification#1 structure: 2nd [enhanced] (or higher) generation security area#1 Ok security area backup saved: id.27EADFDB.[RATECH28_06A_PCB04_GPRS_MT6228_S02.R2000_ML_01_1_0 T02S0824.BIN_753873DE].rpl identification#1 detection finished security area#1 calculation Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... file saved: backup_system_log_27EADFDB_RATECH28_06A_PCB04_GPRS _MT6228_S02.R2000_ML_01_1_0T02S0824.BIN_753873DE_2 0071204-094612.B4X.bin write core area 1 of 2... write core area 2 of 2... error: code: 00000BF4 error: code: 44924492 error: block/offset: 00000C98/00C98000 error: can't write nand core Write Fail file saved: backup_system_log_27EADFDB_RATECH28_06A_PCB04_GPRS _MT6228_S02.R2000_ML_01_1_0T02S0824.BIN_753873DE_2 0071204-102230.B4X.bin Finished, time used: 2265 sec Remove/Install battery now ! |
Hello, Please, use latest "ChineseMiracle" version, charge battery completely, try to repeat flash process several times. if still no luck I think you need to open phone and check phone hardware (f.e. reball CPU and Flash chip). |
Thanks.. I/m using latest chin. miracle 2.06 Using full battery / external voltage... Flashed 3 times... Always stops at 97 % I think it may be hardware... any way thanks for everything. |
