Old 11-08-2007, 08:57   #1 (permalink)
rajumobile's Avatar
Member: 54993
Thanks Meter: 46
ZTC ZT 8380 not supported...
ZTC ZT 8380 dual slim. slide by side youch screen phone...
rx, tx, gnd mentioned on pcb only but not suppported for format or aother operation
Here is log
COM31 [VCP0] selected
Device: Autodetect 6228 NAND
Checking data, wait...
Action: read NAND flash
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6228:8A02:8A02]...
chip-id: 0000:0101
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
version: 3.1
NAND id: ADF1801D
page size: 800+40
pages/block: 40
bits i/o: 08
address cycles: 04
blocks: 0400
ram size: 00800000
NOR: 0000:000000000000 [00000000]
NAND: 00AD:00F10080001D [08400000]
warning: NOR flash chip not supported or not detected
Initialize Done
Set baud...
115200
Set baud Done
Identification...
converting data...
done
protocol ver: 04
ver. sw1: RATECH28_06A_PCB04_GPRS_MT6228_S02.R2000_ML_01_1_0 T02S0824.BIN
ver. sw2: R2000_ML_01_1.0T02S0824
ffs offset/size: 02000000/06000000
id-page Ok
nfi area detection finished: Ok
structure: 2nd [enhanced] (or higher) generation
identification data Ok
identification data backup saved: id.27EADFDB.[RATECH28_06A_PCB04_GPRS_MT6228_S02.R2000_ML_01_1_0 T02S0824.BIN_753873DE].rpl
New firmware detected: RATECH28_06A_PCB04_GPRS_MT6228_S02.R2000_ML_01_1_0 T02S0824.BIN
- make "Read detailed information" operation
- send "backup_system_log_..." file to support
- make "Read full flash" operation
- send flash backup file(s) to support
- include in your e-mail full text from phone back label (phone name etc.)
identification detection finished
WHILE read full flash it gives error...
Boot...
19200
Connecting, wait...
chip-id: 0000:0101
Boot Done
Initialize...
version: 3.1
NAND id: ADF1801D
page size: 800+40
pages/block: 40
bits i/o: 08
address cycles: 04
blocks: 0400
ram size: 00800000
Initialize Done
Set baud...
115200
Set baud Done
Identification...
converting data...
done
protocol ver: 04
id-page Ok
error: unexpected answer:
error: unexpected answer: E0
identification data damaged, recalculation required
warning: probably errors exist during flash read operation
Finished, time used: 200 sec
Remove/Install battery now !
Any solutions please.
thanks.
Old 11-08-2007, 13:23   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Hello,
Please, try to repeat flash rea doperation several times.
Also, try to disconnect and connect box again and reboot PC, this may helps.
Also, if you have any created "backup_system_log..." files with name loke "RATECH28_06A_PCB04_GPRS_MT6228_S02.R2000_ML_01_1_ 0 T02S0824" please, send it to [email protected]
Waiting for yor results.
Old 11-08-2007, 14:40   #3 (permalink)
rajumobile's Avatar
Member: 54993
Thanks Meter: 46
Tried everything but same was happened.
Noe the Phone is back with cusomer.
the said backup_system lig file has been send to yr mail.
thanks for prompt reply
Old 11-24-2007, 06:28   #4 (permalink)
rajumobile's Avatar
Member: 54993
Thanks Meter: 46
Any news about ZT 8380 support or success anybody please.
Old 11-29-2007, 12:42   #5 (permalink)
rajumobile's Avatar
Member: 54993
Thanks Meter: 46
@ infinity support
what happens next...after sending log file no reply.
please help.
ZT 8380 will be supported or not..?
thanks.
Old 11-29-2007, 13:19   #6 (permalink)
Member: 39069
Sonork: 100.1606677
Thanks Meter: 190
ready support. check flash in support area
Old 11-30-2007, 09:17   #7 (permalink)
rajumobile's Avatar
Member: 54993
Thanks Meter: 46
Thanks but it refuse to format ffs.
Old 11-30-2007, 10:05   #8 (permalink)
rajumobile's Avatar
Member: 54993
Thanks Meter: 46
Flash file downloaded from support
using latest chin. miracle 2.05
still error while flashing...please help
Loading data, wait...
S/N: 13F2:010C
Wait...
Device: Autodetect 6205-6227 NOR
Done
Loading file v.02...
ZTC-ZT8380_SZMI26_05C_ZHONGYING_PCB01_GPRS_MT6226_S01[1].SZMI26_05C_W0624_M300TS_V1_0_16m_En_Cn_Cn.B0M.bin loaded
identification#1 protocol ver: 04
ver. sw1: SZMI26_05C_ZHONGYING_PCB01_GPRS_MT6226_S01.SZMI26_ 05C_W0624_M300TS_V1_0.BIN
ver. sw2: SZMI26_05C_W0624_M300TS_V1.0
You have loaded file with security features enabled.
Languages: En Cn Cn
COM3 [VCP0] selected
Action: write NAND flash
write: Firmware
skip: Customization
skip: Language Pack
skip: Eeprom
warning: incorrect bootloader header
error: unknown source file structure
Old 11-30-2007, 15:03   #9 (permalink)
Member: 130995
Hello,
Exist different ZTC-ZT8380 phones: with MT6226 and with MT6228 CPU.
Your phone was with MT6228 CPU but you try to load file for MT6226 CPU and software can't use MT6226 file for MT6228 phone flashing !
Old 12-01-2007, 21:42   #10 (permalink)
rajumobile's Avatar
Member: 54993
Thanks Meter: 46
Thanks for yr attention.
Is there flash file exist for cpu MT6228 please.
Old 12-01-2007, 22:32   #11 (permalink)
Member: 130995
Hello,
support area -> \flashfiles\ChineseMiracle\_MT6228\RATECH28_06A_PC B04_GPRS_MT6228_S02.R2000_ML_01_1_0T02S0824__ZTC-ZT8380_128m_En_Fr_Vn_Ru_Ar_Th.B4M.bin
Old 12-04-2007, 05:57   #12 (permalink)
rajumobile's Avatar
Member: 54993
Thanks Meter: 46
Thanks for support, file downloaded and flashed but still error..
the logs are here...
any advise please.....
write: Firmware
skip: Customization
skip: Language Pack
skip: Eeprom
id-page Ok
Boot...
19200
Connecting, wait...
chip: 0031:0000:0101
Boot Done
Initialize...
version: 3.1
NAND id: ADF1801D
page size: 800+40
pages/block: 40
bits i/o: 08
address cycles: 04
blocks: 0400
ram size: 00800000
NOR chip is not installed
Initialize Done
Set baud...
115200
Set baud Done
Identification...
reading...
detecting structure...
converting data...
done 0x00080000 bytes
id-page Ok
identification#1 structure: 2nd [enhanced] (or higher) generation
security area#1 Ok
security area backup saved: id.27EADFDB.[RATECH28_06A_PCB04_GPRS_MT6228_S02.R2000_ML_01_1_0 T02S0824.BIN_753873DE].rpl
identification#1 detection finished
security area#1 calculation
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
file saved: backup_system_log_27EADFDB_RATECH28_06A_PCB04_GPRS _MT6228_S02.R2000_ML_01_1_0T02S0824.BIN_753873DE_2 0071204-094612.B4X.bin
write core area 1 of 2...
write core area 2 of 2...
error: code: 00000BF4
error: code: 44924492
error: block/offset: 00000C98/00C98000
error: can't write nand core
Write Fail
file saved: backup_system_log_27EADFDB_RATECH28_06A_PCB04_GPRS _MT6228_S02.R2000_ML_01_1_0T02S0824.BIN_753873DE_2 0071204-102230.B4X.bin
Finished, time used: 2265 sec
Old 12-04-2007, 16:27   #13 (permalink)
Member: 130995
Hello,
Please, use latest "ChineseMiracle" version, charge battery completely, try to repeat flash process several times.
if still no luck I think you need to open phone and check phone hardware (f.e. reball CPU and Flash chip).
Old 12-04-2007, 22:28   #14 (permalink)
rajumobile's Avatar
Member: 54993
Thanks Meter: 46
Thanks..
I/m using latest chin. miracle 2.06
Using full battery / external voltage...
Flashed 3 times...
Always stops at 97 %
I think it may be hardware...
any way thanks for everything.
Old 06-11-2009, 06:29   #15 (permalink)
Member: 573044
TRY THIS ....http://support.mientaygsm.com:33/sup...CHINA_MOBILES/
ztc s601 vedios not supported cellcare prasad Chinese Models & Cloned Phones 0 09-12-2008 08:50
ztc zt 8380 again asco777 Infinity-Box 7 05-10-2008 17:22
Ztc Zt-8380 Flash sarasa Chinese Models & Cloned Phones 0 05-05-2008 16:39
sucessfull ztc zt 8380 flashhank asco777 Infinity-Box 2 03-19-2008 18:56
ZTC zt 8380 connection problem asco777 Infinity-Box 4 03-14-2008 17:58
Page generated in 0.42496 seconds with 8 queries
