12-30-2007, 15:27 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | ZTC (ZT588) flashing problem my zt588 is dead , first i format ffs (safe) and complet but set is still dead then i try to flash it from the file witch i download from support erea but facing this error.......here is log COM9 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled Action: write NOR flash "smart write" active write: Firmware skip: Customization skip: Language Pack skip: Eeprom/ffs Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... chip: 0031:4DCC:2550 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:04300400000000 flash: Samsung D 16Mb detecting chip #01 in region #00... flash: EC257E25082501:04300400000000 flash: Samsung D 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:04300400000000 flash: Samsung D 16Mb detecting chip #01 in region #00... flash: EC257E25082501:04300400000000 flash: Samsung D 16Mb it's time to stop: 041C04300822002102F748ED0A4823214901401865714078 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: EC257E25082501:04300400000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00600000 Detected eeprom/ffs address is non-standard: 00600000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00600000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00A00000 ffs chip: 00 eeprom/ffs area: 00000000:00600000-00FFFFFF reading [eeprom]... warning: wrong data size at 0x009B9C00, retry... read error recovered warning: wrong data size at 0x009F5C00, retry... read error recovered file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom_200 71227-084732.B0E.bin flash: EC257E25082501:04300400000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished security area#1 calculation... done Area: Firmware flash: EC257E25082501:04300400000000 Write: Firmware error: error# 000000E4 error: flash write error: 00102000:00002000 Write Fail Finished, time used: 445 sec Remove/Install battery now ! |
12-30-2007, 20:58 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! was this phone dead when you recieved? I am asking, because, your log file looks like it is from flash IC damaged phone. try to flash it one more time with different settings of "advanced chip detection method" and post result |
12-31-2007, 05:20 | #3 (permalink) |
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | yes set was dead when i received .........but it switches on when lay it under 100w balub for 15 min .........and again become dead itself after some time....for this i try to flash it but facing above error.........now set is dead........and not going to switches on by heating it under bulab heat as befre |
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 | rafik2533 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-04-2010 20:38 |
chinese phone ZTC ZT11 - internet problem | vregecc | Chinese Models & Cloned Phones | 1 | 02-14-2009 17:56 |
N88 ZTC 1109 write flash problem | hooi76 | VE-PRO BOX | 0 | 10-18-2008 07:38 |
ZTC ZT166 restart problem!!! | shuric | Infinity-Box | 1 | 02-03-2008 07:31 |
Ztc N328 Strange Problem | υИқИΘШИ® | Infinity-Box | 18 | 01-08-2008 23:09 |
