04-08-2008, 21:38 | #1 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | ZTC ZT8380 and autopinfinder this is my first set after getting my new auto pinfinder ... when i try to find the pinout of this set with auto pinfinder , i am always getting this error .. please help me what is the problem ? ==== log opened: [09/04/2008 1:51:29 AM] ==== Application: C:\Program Files\InfinityBox\PinFinder\PinFinder.exe Initializing... software version: 1.07 Smart-Card S/N: ***x Smart-Card firmware version: 010E Initializing PinFinder... Initializing database... base database version: 01 user database version: 01 Initializing cable list... Initializing platforms... Initialization finished error: can't open COM8 COM2 ready searching adapter at COM2... adapter found, version: 2000 Serial No: *********************x done Initializing... done Cable: 2x6 (L12B) Power Off ! software version: 1.07 cable type: 2x6 (L12B) platform: MT6205, MT6217-MT6228 searching adapter at COM2... warning: 2nd answer absent too many retries adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... warning: 2nd answer absent too many retries warning: 2nd answer absent too many retries warning: 2nd answer absent too many retries warning: 2nd answer absent too many retries warning: 2nd answer absent too many retries warning: 2nd answer absent too many retries warning: 2nd answer absent too many retries warning: 2nd answer absent too many retries warning: 2nd answer absent too many retries warning: 2nd answer absent too many retries warning: 2nd answer absent too many retries warning: 2nd answer absent too many retries warning: 2nd answer absent too many retries warning: 2nd answer absent too many retries warning: 2nd answer absent too many retries warning: 2nd answer absent too many retries warning: 2nd answer absent too many retries warning: 2nd answer absent too many retries warning: 2nd answer absent too many retries failed to detect pins time required: 167 sec too many retries too many retries Power On ! too many retries too many retries too many retries Power On ! |
04-09-2008, 00:41 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Please, download latest PinFinder manual: http://www.infinity-box.biz/download..._PinFinder.pdf Please, see page 19: Automatic pinout detection: Troubleshooting I hope you can solve at least 99% of possible problems (especially with 8, 12, 14, 15 pins cables) with this instruction. |
04-09-2008, 05:50 | #3 (permalink) |
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | i have tried to connect two china mobiles .. but in both of them i am getting this same error too many retries .. i have not opened my infinity box yet .. |
04-09-2008, 11:54 | #5 (permalink) |
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | searching pinout without connecting any mobile to the adapter shows this .. software version: 1.07 cable type: 1x8 (L8A) platform: MT6205, MT6217-MT6228 searching adapter at COM7... adapter found, version: 2000 pins: 8, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... failed to detect pins time required: 28 sec Power Off ! |
04-09-2008, 16:39 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! can you check with which cables you getting search error "error too many retries, warning: 2nd answer absent". and whith which cables you getting normal end like in post above? you can select cable type as L5A, to make search faster |
04-09-2008, 18:35 | #7 (permalink) |
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | the phone which i have now is zt8380 in which there is cable type: 2x6 (L12B) connector which i want to connect , and there i am getting this error .. when i connect the phone .. what should i do ? please help .. |
04-09-2008, 23:37 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! there could be problem inside you L12B cable. that is why i asking you to check with other cables (without phone connected) if they are giving same error or pinout search end normaly ? |
04-10-2008, 06:27 | #10 (permalink) |
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | this is the log of my cable finding... software version: 1.07 cable type: 2x6 (L12B) platform: MT62xx (autodetect) searching adapter at COM8... adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6228 result: Rx:7 Tx:6 time required: 32 sec Power On ! |
04-10-2008, 18:49 | #12 (permalink) |
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | i connect it to another pc then it was working ... then when i connect it to the first pc it also worked there .. i too donno what was the problem .. i think it is cable or connectivity problem .. |
04-12-2008, 20:12 | #13 (permalink) |
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | sir i got the problem y i do get this error warning: 2nd answer absent too many retries this error comes when i do use COM PORT 1 or 2 with Infinity .... i am unable to use COM PORT 1 and 2 with Infinity and auto pin finder .. please help me .. thanks |
04-12-2008, 20:46 | #14 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! you must select com port not based on your wish, but basing on windows device manager. check which com port took your infinity box- this will be your pinfinder com port |
04-12-2008, 21:21 | #15 (permalink) |
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | i want to use com port 1 for a selected program to connect a mobile .. so i connect the auto pinfinder adapter to the second RJ45 socket in my infinity box and connect the infinity box to the COM PORT 1 of my PC . will it work ? |
Pls, i need pinout for ZTC ZT8380!!! tnx | lucsogo | Infinity-Box | 9 | 03-16-2008 15:31 |
Ztc Zt8380 | ave_ret | HTC & PDA WM( With Touchscreen) | 0 | 02-06-2008 10:46 |
How to Hard Reset ZTC ZT8380?? | lucsogo | HTC & PDA WM( With Touchscreen) | 0 | 02-04-2008 00:45 |
Chinese Phone ZTC ZT8380 | davidf | Infinity-Box | 3 | 10-21-2007 12:06 |
