03-24-2009, 20:12 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! also check what CPU it is based. you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software |
03-25-2009, 21:32 | #5 (permalink) |
03-26-2009, 19:22 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! very easy method. Full charged battery & multimeter is only needed. hardest is to get out of phone negative wire. 1. set multimeter to voltage measuring. 2. check bettery voltage, it should be more than 3,7volts 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal. some people use needle (black wire) like on picture here: http://forum.gsmhosting.com/vbb/atta...7&d=1236989648) 4. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
Suo Xin ZT888 Phone Battery Case (Black) | IPMART | ipmart WebShop | 0 | 08-27-2008 11:52 |
Suo Xin ZT888 Phone Battery Case (White) | IPMART | ipmart WebShop | 0 | 08-27-2008 11:52 |
Suo Xin ZT888 Phone Earphone | IPMART | ipmart WebShop | 0 | 08-27-2008 11:52 |
Suo Xin ZT888 Phone USB Data Cable | IPMART | ipmart WebShop | 0 | 08-27-2008 11:52 |
Suo Xin ZT888 Phone Charger | IPMART | ipmart WebShop | 0 | 08-27-2008 11:52 |
