Old 04-23-2008, 19:48   #1 (permalink)
digital_park's Avatar
Member: 681183
Thanks Meter: 165
Exclamation ZTE 125 PinFinder But Don't Work
Sir I buy pinfinder with all uni cable, i manual set rx tx With cable name L8A 1: phone Tx 2: phone Rx then click on “Power” button to enable phone power then press “Set” button. i also try with reverse when i try read flash and press the power button my phone does not boot. its start and ask for insert sim is this prosedure is ok if not tell me right prosedure thanks
Old 04-23-2008, 20:42   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
you must try to reverse pins as well as swap them.
select cable L8A, set data pins 1:2, set power On, try to connect.
if fail: push reverse, try to connect
if fail set data pins 2:1 and repeat
if not work: reverse
after you find correct pinout pinout: save it for future work by "pinout saving feature"
Old 04-24-2008, 04:43   #3 (permalink)
Member: 681183
Thanks Meter: 165
Smile Thanks Infinity Team
Yes I done it And i don't need to buy a new cable for new handset great team
Old 04-24-2008, 10:58   #4 (permalink)
obioha's Avatar
Member: 121356
Thanks Meter: 73
good work infinity team.i tried pinfinder with zte a61,it connects well
Old 04-24-2008, 16:09   #5 (permalink)
Member: 128745
Thanks Meter: 16,936
thankyou all for your good test results.
zte 125 unlocked but still locked gsmservices Infinity-Box 9 06-21-2008 10:15
ZTE 125 unlock but ...... asco777 Infinity-Box 5 04-08-2008 08:26
Unlock codes read but don't work? goodbyegti NEC 1 05-14-2005 20:26
Unlock codes read but don't work? goodbyegti NEC 0 05-14-2005 19:55
I have Sagem unlock cracked by GSM Brothers but don't work!!!1 florinmar Infineon C16X M51 & ARM7 M52 BASED 0 04-01-2002 17:06
Page generated in 0.18806 seconds with 9 queries
