03-07-2010, 08:04 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: philippines now here in U.A.E Age: 38
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | 5310 after write flashing the phone dosn't power on module v3.10 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware CM_Nokia-5310-NMM-3-XPress-Music_SHINEC25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_ W07_16_L5_MP4_MY_V1_1_16m_En_Ru_Fr_Th_Vn_Cn_Ar_w_e ep.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:AA03:0002 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01027E02200200:18C59F00000000 flash: AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01027E02200200:18C59F00000000 flash: AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 01027E02200200:18C59F00000000 flash: AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 01027E02200200:18C59F00000000 flash: AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.10, database date: 02.03.2010): SCUD_GEMINI_PCB1_GPRS_MT25_S067B_A_V0.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 04 sw version: SCUD_GEMINI_PCB1_GPRS_MT25_S067B_A_V0.BIN project-id: 67B_A.V0, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Code CRC check error fix... firmware do not have "Code CRC check error" area Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 01027E02200200:18C59F00000000 Write: Firmware sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 15 min 27 sec Remove/Install battery now ! need help |
03-07-2010, 08:45 | #3 (permalink) |
No Life Poster Join Date: Aug 2004 Location: With old & new friends Age: 49
Member: 79640 Status: Offline Sonork: 1577251 Thanks Meter: 238 | Is is not very easy to help with chinses phones :d but, I think you flashed phone with wrong firmware. try this from support area SCUD_GEMINI_PCB01_GPRS_MT6225_S00.617B_A_V10_04_16 m_En_Ru_Fr_Es_Vn_Cn_Tr_Farsi_Pt_Ar.B0M.bin After flashing phone, sometimes you need to format and/or write good eeprom, repair security etc... Best regards |
The Following User Says Thank You to dzunlocker For This Useful Post: |
china mobile write flash ok but not power on | faisal_fs | Chinese Models & Cloned Phones | 4 | 09-11-2012 06:39 |
6070 After write Flash Cehcksum Phone show Phone is Restricted..... | amol_sm | Universalbox | 8 | 07-28-2008 01:16 |
After flash G7100 phone not powered on | foony | Blazer | 0 | 10-12-2004 13:30 |
