03-03-2009, 12:24 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: pakistan
Member: 361094 Status: Offline Sonork: 100.1597521 Thanks Meter: 172 | zte a136 unlock with infinty module v1.60 Device: Zong-A136 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20090303-161905.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20090303-161906.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20090303-161913.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20090303-161926.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 53 sec Remove/Install battery now ! great work infinty |
The Following 2 Users Say Thank You to nadim electro For This Useful Post: |
03-03-2009, 16:10 | #2 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
ZTE-A136 Unlocked With Sagem EG | .::Skylinks::. | SAGEM JTAG UNLOCKER | 13 | 02-11-2010 09:40 |
Zte a136 unlock method without software | shmily | ZTE | 4 | 11-24-2008 21:29 |
zte a136 unlock failed | gsmexpertgsmexp | Infinity-Box | 6 | 11-21-2008 13:51 |
ZTE A136 Unlocking Cable | IBMOBILES | Main Sales Section | 0 | 11-03-2008 11:11 |
Zong ZTE A136 successfuly With Sagdd | Sahil2007 | SAGEM JTAG UNLOCKER | 1 | 09-23-2008 08:04 |
