11-27-2008, 20:32 | #1 (permalink) |
Freak Poster Join Date: Nov 2004 Location: inside nck Age: 42
Member: 91558 Status: Offline Thanks Meter: 66 | zte a211 unlock done module v2.48 Action: unlock unlock method: smart fast Model: ZTE-A211 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:31FC:000C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: PE-PT-TMN-P109A2V1.0.2B05 Version: 07AZTENJ23_07A_PMJ 44 byte(s) read imei: 35547302011433 connection Ok 157 byte(s) read reading data... building new data... writing data... 145 byte(s) read reading data... building new data... writing data... verifying... verification Ok done Finished, time used: 12 sec Remove/Install battery now ! thanks to infinity team |
The Following User Says Thank You to Terrab.s For This Useful Post: |
11-27-2008, 21:02 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
07-08-2009, 09:51 | #4 (permalink) | |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 | |
@InfinitySupport: ZTE-A136(ZONG) Unlock Done | yawarniazi | Infinity-Box | 143 | 02-03-2009 12:45 |
ZTE A35 unlock done without any problem | mitch_md3 | Infinity-Box | 3 | 01-16-2009 00:06 |
zte A36 unlock done but still locked | tolski | Infinity-Box | 8 | 05-29-2008 14:57 |
vodafone zte 225 unlock done | vodafone_banha | FuriousGold | 7 | 02-24-2008 21:49 |
