Old 01-16-2009, 02:33   #1 (permalink)
gsmbac's Avatar
Member: 44229
Sonork: 1592530
Thanks Meter: 366
ZTE A35 no network after unlock.
unlock log,
COM25 [VCP1] selected
module v1.60
Device: ZTE-A35
Checking data, wait...
Action: unlock
unlock method-1
Boot ...
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
sw version: ARO-P108A7 Z B01-EnEs-PE02 g3dBV2.0 Sep 28 2007 04.12.00 18.26.1
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: E:\mobile\infinity box\InfinityBox\Pana01\ZTE-A35_eeprom-static_20090114-175218.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: E:\mobile\infinity box\InfinityBox\Pana01\ZTE-A35_eeprom-security_20090114-175219.B1E.bin
reading eeprom-complete...
file saved: E:\mobile\infinity box\InfinityBox\Pana01\ZTE-A35_eeprom-complete_20090114-175220.B1E.bin
reading additional data...
file saved: E:\mobile\infinity box\InfinityBox\Pana01\ZTE-A35_lock-area_20090114-175225.B1E.bin
backup critical area Done
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 33 sec
after unlock show full network bars, but "searching" displayed (not registering to network)
imei rebuild ok but same,
try to restore ee backups.
always error when try to restore "ZTE-A35_eeprom-security_20090114-181336.B1E.bin"
module v1.60
Device: ZTE-A35
Action: flash write
Boot ...
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
Check hardware Done
file saved: E:\mobile\infinity box\InfinityBox\Pana01\ZTE-A35_eeprom-static_20090114-181335.B1E.bin
loading data...
data loaded
file saved: E:\mobile\infinity box\InfinityBox\Pana01\ZTE-A35_eeprom-security_20090114-181336.B1E.bin
file saved: E:\mobile\infinity box\InfinityBox\Pana01\ZTE-A35_eeprom-complete_20090114-181337.B1E.bin
Check memory ...
Check memory Done
Write ...
reset...
done
Erasing: Eeprom
error: set erase range
error: erase failed: 007F8000
Write Failed
Finished, time used: 21 sec
any ideas?
Old 01-16-2009, 14:43   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Did you treid to make 112/emergency calls without sim card ?
What is the results ?
Old 01-16-2009, 15:04   #3 (permalink)
gsmbac's Avatar
Member: 44229
Sonork: 1592530
Thanks Meter: 366
cannot make 112 without sim,
i try restore backup again,
everything ok, but cannot load lock area backup file.
log,
Loading file v.02...
error: data error !
Loading failed, probably damaged data file
error: data error !
other areas restored.
br.
Old 01-16-2009, 15:38   #4 (permalink)
Member: 130995
Hello,
We never heard about network problems after unlock.
If phone can not make 112/emergency call it may be hardware problem (damaged hardware) or problems with band selection.
As I can see your phone has this firmware: CLARO-P108A7(Z)B01-EnEs-PE02_g3dBV2.0_Sep-28-2007
This means that this phone comes from America so you must compare American band with your local network operators band.
Old 01-16-2009, 15:55   #5 (permalink)
gsmbac's Avatar
Member: 44229
Sonork: 1592530
Thanks Meter: 366
i agree with u ,
i unlocked lot of ZTE, vodafone but never had this kind of problem.
br.
Old 01-16-2009, 16:07   #6 (permalink)
gsmbac's Avatar
Member: 44229
Sonork: 1592530
Thanks Meter: 366
problem solved,
this is 100% software fault.
i flashed this file first
ZTE-A35_Main_LP_TELMA-P108A5B01-Fr-MG01_g3dBV2.0_Jun-19-2007.B1M.bin
log,
COM25 [VCP0] selected
module v1.60
Device: ZTE-A35
Action: flash write
Boot ...
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
Check hardware Done
file saved: E:\mobile\infinity box\InfinityBox\Pana01\ZTE-A35_eeprom-static_20090116-202012.B1E.bin
loading data...
data loaded
file saved: E:\mobile\infinity box\InfinityBox\Pana01\ZTE-A35_eeprom-security_20090116-202012.B1E.bin
file saved: E:\mobile\infinity box\InfinityBox\Pana01\ZTE-A35_eeprom-complete_20090116-202013.B1E.bin
Check memory ...
Check memory Done
Write ...
reset...
done
Erasing: Firmware
Writing: Firmware
Write Done
Finished, time used: 86 sec
Remove/Install battery now !
then i flashed ZTE-A35_repair_eeprom_complete_01.B1E.bin file
log,
module v1.60
Device: ZTE-A35
Action: flash write
Boot ...
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
sw version: LMA-P108A5B01-Fr-MG01 g3dBV2.0 04.12.00 18.26.11 08.02.00 EF-MG-
Check hardware Done
file saved: E:\mobile\infinity box\InfinityBox\Pana01\ZTE-A35_eeprom-static_20090116-202221.B1E.bin
loading data...
data loaded
file saved: E:\mobile\infinity box\InfinityBox\Pana01\ZTE-A35_eeprom-security_20090116-202221.B1E.bin
file saved: E:\mobile\infinity box\InfinityBox\Pana01\ZTE-A35_eeprom-complete_20090116-202222.B1E.bin
Check memory ...
Check memory Done
Write ...
reset...
done
Erasing: Eeprom
Writing: Eeprom
Write Done
Finished, time used: 17 sec
after above phone can make 112,
but sim locked,
then i unlocked,
module v1.60
Device: ZTE-A35
Action: unlock
unlock method-1
Boot ...
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
Check hardware Done
file saved: E:\mobile\infinity box\InfinityBox\Pana01\ZTE-A35_eeprom-static_20090116-202407.B1E.bin
loading data...
data loaded
file saved: E:\mobile\infinity box\InfinityBox\Pana01\ZTE-A35_eeprom-security_20090116-202407.B1E.bin
file saved: E:\mobile\infinity box\InfinityBox\Pana01\ZTE-A35_eeprom-complete_20090116-202409.B1E.bin
file saved: E:\mobile\infinity box\InfinityBox\Pana01\ZTE-A35_lock-area_20090116-202413.B1E.bin
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 25 sec
now phone work 100% but imei damaged. (004999010640000)
br.
Old 01-16-2009, 16:39   #7 (permalink)
Member: 130995
Hello,
Just try to repair imei now.
Old 03-01-2009, 02:30   #8 (permalink)
denisirias's Avatar
Member: 309299
Thanks Meter: 259
well i have same problem no network i try what mate say flash with telma then repair eprom then unlock but phone still have nonetwork im trying to use phone in 1900 band without success any advice will be great phone is brand new
Old 03-01-2009, 08:31   #9 (permalink)
Member: 130995
Hello,
I am sure it is not a problem after unlock but it's a ordinary problem with band incompatibility for European/American models.
What network this phone was locked ?
Did you tried to make 112/emergency call before unlock ?
What is phone first imei digits ?
Old 03-01-2009, 16:02   #10 (permalink)
denisirias's Avatar
Member: 309299
Thanks Meter: 259
Originally Posted by InfinitySupport View Post
Hello,
answers for your questions
the phone was locked to claro guatemala that use band 1900
in this part of the world they dont use the emergency call system
the first digit of imei is 356 those are the first 3 digits
Old 03-01-2009, 18:33   #11 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 213
Are you sure that phone was 100% working before unlock and it has no problems with network ?
Old 03-01-2009, 18:44   #12 (permalink)
denisirias's Avatar
Member: 309299
Thanks Meter: 259
yes im sure
phone was perfect
Old 03-01-2009, 19:02   #13 (permalink)
Member: 130995
Hello,
How is it possible to be sure that phone was completely good if you did not tried to make 112/emergency or other call type ?
Please, tell me more about your phone condition and tests that you have tried to do before unlock.
I am really interested to get more detailed information about this problem due to we never have seen any problem with this kind of phones after unlock.
Waiting for your explanation about tests that was done with phone before and after unlock.
Old 03-01-2009, 21:44   #14 (permalink)
denisirias's Avatar
Member: 309299
Thanks Meter: 259
Well im sure phone was right before cause when came to my store came with original sim it was locked to and had full signal with rooming service then in just use unlock botton and phone now dont have network
The test i perform was
Flash
Write eprom
Unlock
Repair imei
I have try all flash files from support
The only thing i havent do is write original flash file i save from phone as always before any operation
Old 03-01-2009, 22:12   #15 (permalink)
Member: 130995
Did you tried to test phone with original sim card after unlock ?
Zte 112 no network after unlock MDK23 FuriousGold 16 07-22-2013 00:20
ZTE MF100 no network after unlock ?? .:RoMeO:. MDM Service Tools 7 10-30-2010 01:46
5110 i no network after unlocking need help gsnbhagawan Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 03-19-2002 18:02
MC939 no network after unlock Dream gsm Infineon C16X M51 & ARM7 M52 BASED 0 01-24-2002 22:35
No Network after unlocking ? Squesch Alcatel & TCL Old Models 3 10-17-2000 08:43
Page generated in 0.28159 seconds with 9 queries
