08-26-2009, 05:47 | #1 (permalink) |
Insane Poster Join Date: Sep 2007
Member: 587123 Status: Offline Thanks Meter: 7 | Chinese Miracle fail! I have another TV C702 and i could read it with pinfinder very well but when i open Chinese Miracle to know user code, chinese micracle fail and give me this log: COM19 [VCP0] selected module v2.90 Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:4B03:0000 status: FF Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 78 sec Remove/Install battery now ! Please infinity team what can you suggest me? |
08-26-2009, 15:14 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if you did not modify your main infinity box- this is the reason. there is used diode which limit power from 5volt to 4,3v you must shortcut it and then problems with test mode will gone you can find this procedure describtion in pinfinder user manual "trubleshooting section" Last edited by InfinityHelp; 08-26-2009 at 15:45. |
08-26-2009, 19:06 | #5 (permalink) | |
Member: 587123 Status: Offline Thanks Meter: 7 | Quote:
Thank you infinity team! | |
Chinese Miracle module supported models/features [08-Apr-2007]: | inder | Infinity-Box | 2 | 02-05-2010 20:24 |
Chinese Miracle cable set, where?? | armkbdotcom | Infinity-Box | 34 | 03-02-2008 11:45 |
motorola F3 chinese miracle? | mrfixit | Infinity-Box | 3 | 02-19-2007 22:25 |
Chinese Miracle cable set needed ASAP | armkbdotcom | Wanted Products | 1 | 01-19-2007 02:55 |
Chinese miracle telsda mp4?? T6012 | SLIPLOCK | Infinity-Box | 4 | 01-11-2007 00:17 |
