Old 08-25-2009, 00:30   #1 (permalink)
Member: 889831
Thanks Meter: 11
ZTE - A35 problem unlock - flash
i īve 50 phones zte-a35 ...i unlocked 42 but i īve problem wiht 8 units
first problem is when i try unlock,,,,
COM2 [VCP0] selected
module v1.69
Device: ZTE-A35
Checking data, wait...
Action: unlock
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Archivos de programa\InfinityBox\Pana01\ZTE-A35_eeprom-static_20090824-171037.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Archivos de programa\InfinityBox\Pana01\ZTE-A35_eeprom-security_20090824-171038.B1E.bin
reading eeprom-complete...
file saved: C:\Archivos de programa\InfinityBox\Pana01\ZTE-A35_eeprom-complete_20090824-171044.B1E.bin
reading additional data...
file saved: C:\Archivos de programa\InfinityBox\Pana01\ZTE-A35_lock-area_20090824-171102.B1E.bin
backup critical area Done
Check memory ...
error: unknown firmware, read flash and send to support
Check memory Failed
Finished, time used: 42 sec
Remove/Install battery now !
and phone dead,,,,if i try to flash
i wait by 15min and not finish .stoped at 3%...,,,the same problem when itry to flash with eeprom from support
this is the file readed from phone
http://rapidshare.com/files/27107301...1X-readed.html
what can i do ?
thanks.
Old 08-25-2009, 19:32   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,298
Hello,
Phone can not be dead after this operation due to software have detected new firmware version and stop to work. It was done no any changes in phone memory.
Please, double check battery voltage, charge battery if need and phone should be powered-on without problems.
We will check your firmware backup and update software ASAP for this new firmware.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 08-26-2009, 16:20   #3 (permalink)
Member: 889831
Thanks Meter: 11
thanks for reply
problem solved ,,
rehot procesador,,,and then i flash ,, and finished susscelfull.
it was hardware problem ,,
thanks.
The Following User Says Thank You to BLAZTER For This Useful Post:
ZTE A35 Can't Unlock ! Edocomsel Infinity-Box 5 12-03-2009 08:56
zte a35 sucessfully unlocked cellcarekphb Infinity-Box 1 04-21-2009 23:38
zte a35 successfully unlock ashrafi580 Infinity-Box 3 03-30-2009 09:23
ZTE-A35 not unlocked by microbox richardnikko Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 10 10-29-2008 14:20
ZTE A35 Cann't unlock mwmobile2 Infinity-Box 4 07-25-2008 02:11
Page generated in 0.26575 seconds with 8 queries
