08-30-2008, 03:14 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: near Network Age: 48
Member: 185608 Status: Offline Thanks Meter: 592 | ZTE A35 unlock problem look at this: Current model: ZTE-A35 Ready Loading file v.02... ZTE-A35_Main_LP_TELMA-P108A5B01-Fr-MG01_g3dBV2[1].0_Jun-19-2007.B1M.bin loaded COM39 [VCP0] selected Device: ZTE-A35 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 2000:8000 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... backup critical area Done Check memory... Check memory Done Write... Erasing: Firmware error: set erase range error: erase failed: 00400000 Write Failed Finished, Remove/Install battery now ! Time used: 42 sec ************************************************** ********************** COM39 [VCP0] selected Device: ZTE-A35 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 2000:8000 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... backup critical area Done Check memory... Check memory Done Write... Erasing: Firmware error: set erase range error: erase failed: 00400000 Write Failed Finished, Remove/Install battery now ! Time used: 39 sec |
08-31-2008, 16:42 | #3 (permalink) |
Member: 185608 Status: Offline Thanks Meter: 592 | Working! Working fine with one network! But i agree with you.Hardware problem i never seen.I return it to customer. Thank you for your assistance! |
Zte a35+ unlock problem | ismabdi | Martech CLIP / Box / Key | 4 | 12-07-2009 22:41 |
zte a35 unlock problem | frankcelular1 | VygisToolbox | 1 | 08-19-2009 20:50 |
ZTE A35 unlock done without any problem | mitch_md3 | Infinity-Box | 3 | 01-16-2009 00:06 |
zte a35 lock problem | ruvanw1979 | Infinity-Box | 1 | 05-09-2008 08:05 |
Zte 225 (vodafone) And Zte A35 Unlock Help | Nasmi | FuriousGold | 21 | 03-12-2008 21:14 |
