ZTE-A35 unlocking success ZTE-A35 unlock okay http://i171.photobucket.com/albums/u...te/zte-a35.jpg How to unlock ZTE-A35, ZTE-A61 1. Make eeprom and flash backup for emergency case ! 2. Make "unlock" operation 3. Enter code (if possible) 4. If it's not possible to enter code flash phone with the next file: ZTE-A35_Main_LP_TELMA-P108A5B01-Fr-MG01_g3dBV2.0_Jun-19-2007 5. Make "unlock" operation again Cable name: ZTE-225 keyboard top 1..........8 1: phone Tx (RJ-45 pin-3) 2: phone Rx (RJ-45 pin-2) 3: Gnd br keaelite http://www.gsmgenius.com/images/styl...ser_online.gif http://www.gsmgenius.com/images/styl...reputation.gif http://www.gsmgenius.com/images/styl...ons/report.gif http://www.gsmgenius.com/images/styl...c/progress.gif http://www.gsmgenius.com/images/styl...ttons/edit.gif |
nice info bro,congrats....... |
nice sharing your logs mate and nifo about this kind of phone.... |
@keaelite Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
thanks you infinit guys, but i unlock some a61 & 66, but i still some that did not connect, what can i do, or infinit can not unlock this ones, i used pana01 v1.52. |
Hello, C:\\Program Files\\InfinityBox\\Documentation\\Unlock_and_repa ir\\Unlock_ZTE-A35_ZTE-A61.txt |
Version detect with code: *983*7469# version *983*1688# batterie temperature *983*5391# keypad test *983*5651# phone reset and user code reset also *983*757# sim lock info *983*22387# master reset *983*2831# audio test EI-ID-HCPT-P108A5(S)V1.0.0.B01 CAN'T UNLOCK!!!!!! REPORT: Always: COM3 [VCP0] selected module v1.71 Device: ZTE-A35 Checking data, wait... Action: read flash Boot ... Press and HOLD Power button now ! e-gold: 820013 loading... next part... boot answer: 00 error: unknown bootcode answer: Release Power button now Boot Failed Finished, time used: 7 sec Remove/Install battery now ! |
COM3 [VCP0] selected module v1.73 Device: ZTE-A35 Checking data, wait... Boot ... Press and HOLD Power button now ! e-gold: 820013 loading... next part... error: can't run main loader: Finished, time used: 7 sec Remove/Install battery now ! Ver e-gold: 820013 |
same problem e-gold 820013 need help |
COM83 [VCP0] selected module v1.78 Device: ZTE-A35 Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: TEL-P108A5V1.0.0B01 09 56 58 Sep 17 2007 09 56 58 Sep 17 2007 04 Check parameters Done backup critical area ... reading eeprom-static... file saved: c:\InfinityBox\Pana01\ZTE-A35_eeprom-static_20130223-195859.B1E.bin loading data... data loaded reading eeprom-security... file saved: c:\InfinityBox\Pana01\ZTE-A35_eeprom-security_20130223-195900.B1E.bin reading eeprom-complete... file saved: c:\InfinityBox\Pana01\ZTE-A35_eeprom-complete_20130223-195906.B1E.bin reading additional data... file saved: c:\InfinityBox\Pana01\ZTE-A35_lock-area_20130223-195926.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 1 min 6 sec Remove/Install battery now ! |
Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. |
ZTE-A35 phone code remove by infinity Box Code: COM22 [VCP0] selected |
how to read Language Pack for aplly in other device?! |
You can read flash from phone, send it to [email protected] and we can try to prepare flash file that will be possible to write in other similar phones. |
I uploaded the backup file to [email protected] and now I'm waiting for a response. Thank you! |
