10-14-2008, 06:26 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: sn,fdo,lu philippines
Member: 288470 Status: Offline Sonork: 100.1605122 Thanks Meter: 664 | ZTE-A35 unlocking success How to unlock ZTE-A35, ZTE-A61 1. Make eeprom and flash backup for emergency case ! 2. Make "unlock" operation 3. Enter code (if possible) 4. If it's not possible to enter code flash phone with the next file: ZTE-A35_Main_LP_TELMA-P108A5B01-Fr-MG01_g3dBV2.0_Jun-19-2007 5. Make "unlock" operation again Cable name: ZTE-225 keyboard top 1..........8 1: phone Tx (RJ-45 pin-3) 2: phone Rx (RJ-45 pin-2) 3: Gnd br keaelite |
The Following 2 Users Say Thank You to keaelite For This Useful Post: |
10-14-2008, 09:37 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | @keaelite Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
10-29-2008, 10:49 | #5 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Paris
Member: 139718 Status: Offline Thanks Meter: 4 | thanks you infinit guys, but i unlock some a61 & 66, but i still some that did not connect, what can i do, or infinit can not unlock this ones, i used pana01 v1.52. |
12-31-2009, 10:10 | #7 (permalink) |
Insane Poster Join Date: Oct 2006 Location: Indonesia
Member: 368655 Status: Offline Thanks Meter: 20 | Version detect with code: *983*7469# version *983*1688# batterie temperature *983*5391# keypad test *983*5651# phone reset and user code reset also *983*757# sim lock info *983*22387# master reset *983*2831# audio test EI-ID-HCPT-P108A5(S)V1.0.0.B01 CAN'T UNLOCK!!!!!! REPORT: Always: COM3 [VCP0] selected module v1.71 Device: ZTE-A35 Checking data, wait... Action: read flash Boot ... Press and HOLD Power button now ! e-gold: 820013 loading... next part... boot answer: 00 error: unknown bootcode answer: Release Power button now Boot Failed Finished, time used: 7 sec Remove/Install battery now ! |
12-31-2009, 11:00 | #8 (permalink) |
Member: 368655 Status: Offline Thanks Meter: 20 | COM3 [VCP0] selected module v1.73 Device: ZTE-A35 Checking data, wait... Boot ... Press and HOLD Power button now ! e-gold: 820013 loading... next part... error: can't run main loader: Finished, time used: 7 sec Remove/Install battery now ! Ver e-gold: 820013 |
02-23-2013, 16:59 | #10 (permalink) |
No Life Poster Join Date: Aug 2005
Member: 175945 Status: Offline Sonork: ziiyyaad Thanks Meter: 704 | COM83 [VCP0] selected module v1.78 Device: ZTE-A35 Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: TEL-P108A5V1.0.0B01 09 56 58 Sep 17 2007 09 56 58 Sep 17 2007 04 Check parameters Done backup critical area ... reading eeprom-static... file saved: c:\InfinityBox\Pana01\ZTE-A35_eeprom-static_20130223-195859.B1E.bin loading data... data loaded reading eeprom-security... file saved: c:\InfinityBox\Pana01\ZTE-A35_eeprom-security_20130223-195900.B1E.bin reading eeprom-complete... file saved: c:\InfinityBox\Pana01\ZTE-A35_eeprom-complete_20130223-195906.B1E.bin reading additional data... file saved: c:\InfinityBox\Pana01\ZTE-A35_lock-area_20130223-195926.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 1 min 6 sec Remove/Install battery now ! |
The Following User Says Thank You to ZIYAAD STRYKER For This Useful Post: |
02-25-2013, 13:09 | #11 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. |
04-12-2013, 15:14 | #12 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Karachi pakistan Age: 41
Member: 388647 Status: Offline Sonork: sheerazi Thanks Meter: 161 | ZTE-A35 phone code remove by infinity Box Code: COM22 [VCP0] selected module v1.78 Device: ZTE-A35 Checking data, wait... Action: reset settings ("format ffs") Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: OBE-P108A5B01-En-PH01 g3dBV2.0 E-PH-GLOBE-P108A5V1.0.0B01 7 Check parameters Done backup critical area ... reading eeprom-static... file saved: c:\InfinityBox\Pana01\ZTE-A35_eeprom-static_20130412-190957.B1E.bin loading data... data loaded reading eeprom-security... file saved: c:\InfinityBox\Pana01\ZTE-A35_eeprom-security_20130412-190958.B1E.bin reading eeprom-complete... file saved: c:\InfinityBox\Pana01\ZTE-A35_eeprom-complete_20130412-190959.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Write Done Finished, time used: 17 sec Remove/Install battery now ! |
The Following User Says Thank You to asif ali For This Useful Post: |
04-26-2013, 16:49 | #14 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | In most cases there is no separate language packs for that phones. You can read flash from phone, send it to [email protected] and we can try to prepare flash file that will be possible to write in other similar phones. |
04-29-2013, 13:04 | #15 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Ubá--Brazil Age: 34
Member: 194078 Status: Offline Sonork: no have Thanks Meter: 208 | I uploaded the backup file to [email protected] and now I'm waiting for a response. Thank you! |
Zte A35 Unlock | abote didier | ZTE | 22 | 07-03-2014 15:49 |
Zte 225 (vodafone) And Zte A35 Unlock Help | Nasmi | FuriousGold | 21 | 03-12-2008 21:14 |
ZTE A35 unlock | Jayrus | Infinity-Box | 6 | 03-11-2008 08:19 |
Zte A35 Unlock | olivium | ZTE | 0 | 02-16-2008 20:26 |
ZTE A35 unlock | NiceLys | Infinity-Box | 1 | 11-21-2007 19:06 |
