11-22-2008, 14:34 | #1 (permalink) |
Freak Poster Join Date: Mar 2007 Location: africa
Member: 461554 Status: Offline Thanks Meter: 55 | ZTE A36 unlock infinity team i read unlock code how can i enterd to phone this when i but sim card i cant type numbers COM75 [VCP0] selected Device: ZTE-A35 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20081124-155438.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\za35_eep65535.cfg error: can't load database v.11 reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_20081124-155441.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_20081124-155449.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 42 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
11-22-2008, 14:44 | #2 (permalink) |
Freak Poster Join Date: Jun 2007 Location: rawalpindi Age: 32
Member: 527709 Status: Offline Thanks Meter: 30 | hi 100% unlock infinity box ZTE-225_Main_VDF-P108A2B06-Tu-TU02_g3dBV2.0_Jun-5-2007.B1M.bin -ZTE-225_LP_VDF-P108A2B06-Tu-TU02_g3dBV2.0_Jun-5-2007_Tr.B1P.bin -ZTE-225_repair_ffs_01.B1F.bin (open as ffs2 and select file) -ZTE-225_repair_eeprom_complete_01.B1E.bin Save all the backups during flashing 2. Unlock ( cancel saving backups during unlocking) 3. Write backup - eeprom sta 4. Write backup - eeprom sec 5. Power ON phone with locked sim 6. Enter Code 12345678 unlock |
The Following User Says Thank You to setool3 For This Useful Post: |
11-22-2008, 14:56 | #3 (permalink) |
Freak Poster Join Date: Feb 2007 Location: Pakistan (Layyah) Punjab Age: 37
Member: 453862 Status: Offline Thanks Meter: 53 | No Need To Flash Simply download Pana01 Ver. 1.56 and just click unlock Your phone will be ok http://www.infinity-box.com/download...na01_v1.56.rar |
The Following User Says Thank You to Tahir Riaz For This Useful Post: |
11-22-2008, 15:13 | #4 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Edmonton AB
Member: 340564 Status: Offline Sonork: 1591034 Thanks Meter: 529 | Quote:
The Following User Says Thank You to kasrawiz For This Useful Post: |
11-23-2008, 00:10 | #8 (permalink) | |
It's no need to flash phone for unlock now, just use latest software from support area. Check message in current thread posted by respected Mr. Tahir Riaz ! | |
11-23-2008, 06:49 | #9 (permalink) |
Member: 461554 Status: Offline Thanks Meter: 55 | THIS IS THE LOGO ==== log: [11/24/2008 5:17:04 PM] ==== COM75 [VCP0] selected module v1.56 Device: ZTE-A35 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-sta... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-sta_20081124-171721.B1E.bin loading data... data loaded reading eeprom-sec... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-sec_20081124-171723.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-complete_20081124-171731.B1E.bin reading additional data... done backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 40 sec Remove/Install battery now ! |
The Following User Says Thank You to ismabdi For This Useful Post: |
11-23-2008, 14:44 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
zte a36 unlock | fida_hussain | Infinity-Box | 4 | 08-09-2008 11:50 |
ZTE A36 unlock problem help plz | asad_nomy7 | Infinity-Box | 10 | 07-08-2008 20:18 |
zte a36 unlocker | agusmardi | Venus Box | 5 | 06-21-2008 10:51 |
zte A36 unlock done but still locked | tolski | Infinity-Box | 8 | 05-29-2008 14:57 |
problem with unlock ZTE A36 | volamihamina | Infinity-Box | 1 | 04-29-2008 07:35 |
