Old 05-31-2008, 11:17   #1 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,067
ZTE A36 unlock problem help plz
i unlock ZTE A36 after succesful unlock software gives instruction for unlock thatower on phone enter code 12345678. i enter code with simcard but after press when i press 2 emergency call only appear and no chance for enter code.i flash it and unlock again but same result.now plz give me trick to enter unlock code. here is logs of unlocking
COM7 [VCP0] selected
Device: ZTE-A36
Checking data, wait...
Action: unlock
unlock method-1
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud...
115200
Set Baud Done
Connecting...
flash: 00EC:22A0
Connecting Done
Check hardware...
flash chip supported
Check hardware Done
Check parameters...
Check parameters Done
backup critical area...
reading [eeprom-sta]...
file saved: C:\Program Files\InfinityBox\Pana01\backup_ZTE-A36_eeprom-sta_20080531-021856.B1E.bin
loading data...
data loaded
reading [eeprom-sec]...
file saved: C:\Program Files\InfinityBox\Pana01\backup_ZTE-A36_eeprom-sec_20080531-021900.B1E.bin
reading [eeprom-complete]...
file saved: C:\Program Files\InfinityBox\Pana01\backup_ZTE-A36_eeprom-complete_20080531-021913.B1E.bin
reading additional data...
done
backup critical area Done
Check memory...
current status: 0
Check memory Done
Write...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, Remove/Install battery now !
Time used: 53 sec
Unlock instruction:
1. Power-On phone
2. Enter code: 12345678
Old 05-31-2008, 11:23   #2 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
what is written on screen when u insert sim in the phone
Old 05-31-2008, 12:00   #3 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,067
on screen written "SIM LOCK" When i enter code it says emergency only.
Old 05-31-2008, 15:14   #4 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
may be your counter is blocked.
Old 05-31-2008, 16:53   #5 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,067
if counter block how i reset it.where is infinity team plz help about this problem.
Old 05-31-2008, 17:02   #6 (permalink)
tolski's Avatar
Member: 34750
Thanks Meter: 177
same as yours....look at this..
https://forum.gsmhosting.com/vbb/f296/zte-a36-unlock-done-but-still-locked-543903/
Old 05-31-2008, 22:00   #7 (permalink)
Member: 130995
Thanks Meter: 35,227
1. Make eeprom and flash backup for emergency case !
2. Make "unlock" operation
3. Enter code (if possible)
4. If it's not possible to enter code flash phone with the next files:
ZTE-225_Main_VDF-P108A2B06-Bg-BG02_g3dBV2.0_May-31-2007
ZTE-225_LP_VDF-P108A2B06-Bg-BG02_g3dBV2.0_May-31-2007_Bg
5. Make "unlock" operation again
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post:
Old 06-01-2008, 11:37   #8 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,067
sir did u mean that flash with ZTE 225 flash file.is this same model ZTE A36 and ZTE 225?.
Old 06-14-2008, 06:58   #9 (permalink)
Member: 396128
Thanks Meter: 10
ZTE-225_LP_VDF-P108A2B06-Bg-BG02_g3dBV2.0_May-31-2007_Bg.B1P.bin
Please sir i need indonesian language
Thanks for u sharing abaut solved problem unlock at ZTE A36 But need Lp indonesian please...
thanks
Old 06-14-2008, 09:05   #10 (permalink)
Member: 130995
thanks
Hello,
Please, read: C:\Program Files\InfinityBox\Documentation\Infinity-Box_How_to_get_latest_flash_files_and_new_language s.txt
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 07-08-2008, 20:18   #11 (permalink)
varalex's Avatar
Member: 170408
Thanks Meter: 120
all is OK
my A36 after this opetation unlocked
thx Infinity team
ZTE A66 unlocking problem, Help! peter pardon Infinity-Box 9 03-15-2010 14:22
LO1A unlocking problem help plz..........? BAHRI PhoneWala FuriousGold 1 08-20-2009 14:15
zte A36 unlock done but still locked tolski Infinity-Box 8 05-29-2008 14:57
W850I UNLOCK PROBLEM help plz webzone136 Cruiser Suite 8 11-19-2007 12:45
616v unlock problems help plz matyus111 NEC 2 05-09-2005 07:21
Page generated in 0.23889 seconds with 10 queries
