08-25-2010, 07:37 | #1 (permalink) |
Freak Poster Join Date: Feb 2008 Location: sri Lanka
Member: 709608 Status: Offline Thanks Meter: 14 | ZTE A36+ while unlocking phone not power on there after tried using model A36FM phone not power on tried to write firmware a36+ cannot accept... looking forward any help from supported people thanks COM8 [VCP3] selected module v1.78 Device: ZTE-A36FM Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 230400 Set Baud Done Connecting ... flash: 4001:8000 Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: LAT-P108A6FMB01-En-AF02 g3dBV2.0 E-AF-ETISALAT-P108A6FMV1.0.0B02 Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36FM_eeprom-static_20100825-105324.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36FM_eeprom-security_20100825-105325.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36FM_eeprom-complete_20100825-105328.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36FM_lock-area_20100825-105336.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area --------------- COM3 [VCP5] selected module v1.78 Device: ZTE-A36FM Checking data, wait... Action: write flash write: Firmware ZTE-A36_main_VELCOM-P108A6B01-EnRu-RU03_Oct-25-2007.B1M.bin skip: FFS-1/Customization write: Language Pack ZTE-A36_lp_VELCOM-P108A6B01-EnRu-RU03_Oct-25-2007.B1P.bin skip: Graphics Pack skip: FFS-2/File system skip: Eeprom Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: COM-P108A6B01-EnRu-RU03 g3dBV2.0 04.12.00 18.26.11 08.02.00 Oct Check parameters Done backup critical area ... backup critical area Done Check memory ... unlocking... lock found lock type #1 found operation done Check memory Done Write ... Erasing: Firmware error: set erase range error: erase failed: 00400000 Write Failed Finished, time used: 29 sec Remove/Install battery now ! |
The Following User Says Thank You to helperer For This Useful Post: |
08-25-2010, 10:38 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hi, As I can see flash chip can not be detected and written well. It may be that this phone hardware has a problems. Double check battery voltage and charge it with external power supply. Repeat flash write process several times. What is the results ? |
08-26-2010, 08:28 | #3 (permalink) |
Member: 709608 Status: Offline Thanks Meter: 14 | thank for your advice flashed successful not power on apraciated any help or advice tried to write eeprom all the time error in 12% COM3 [VCP4] selected module v1.78 Device: ZTE-A36 Checking data, wait... Action: write flash write: Firmware ZTE-A36_CLARO-P108A8(Z)B01-EnEs-PE02_Claro-Peru_firmware.B1M.bin skip: FFS-1/Customization write: Language Pack ZTE-A36_CLARO-P108A8(Z)B01-EnEs-PE02_Claro-Peru_lp.B1P.bin skip: Graphics Pack skip: FFS-2/File system skip: Eeprom Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .00 P108A6 SST V1.0.0B06 P108A6V1.0.0B06 g3dBV2.0 Dec 7 2007 14 Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-static_20100826-123409.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-security_20100826-123410.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-complete_20100826-123416.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware Writing: Firmware Erasing: Firmware Writing: Firmware Erasing: Language Pack Writing: Language Pack Write Done Finished, time used: 6 min 48 sec Remove/Install battery now ! COM3 [VCP4] selected module v1.78 Device: ZTE-A36 Checking data, wait... Action: write flash skip: Firmware skip: FFS-1/Customization skip: Language Pack skip: Graphics Pack skip: FFS-2/File system write: Eeprom ZTE-A36_eeprom-complete_04.B1E.bin Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: -PE-P108A8 Z V1.0.0B02 12 09 06 CLARO-P108A8 Z B01-EnEs-PE02 g3d Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-static_20100826-125741.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-security_20100826-125742.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-complete_20100826-125748.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Eeprom Writing: Eeprom repair write error [007F2000:0800]... error: write failed[007F0000] Write Failed Finished, time used: 45 sec Remove/Install battery now ! |
08-26-2010, 18:03 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, A I can see from first log, original firmware was like ZTE-A36_main_lp_ETISALAT-P108A6FMB01-En-AF02_Jul-9-2008.B1M.bin so try to flash phone with this file from support area: ZTE-A36_main_lp_ETISALAT-P108A6FMB01-En-AF02_Jul-9-2008.B1M.bin Eeprom file: ZTE-A36_repair_eeprom_static_02.B1E.bin Let's see results. |
08-27-2010, 08:51 | #5 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Venezuela
Member: 594580 Status: Offline Thanks Meter: 157 | Same problem here.. I did Security Code reset then now phone is DEAD.. Ive tried many times to write EEPROM backup but not success.. COM4 [VCP0] selected module v1.78 Device: ZTE-A36 Checking data, wait... Action: write flash skip: Firmware skip: FFS-1/Customization skip: Language Pack skip: Graphics Pack skip: FFS-2/File system write: Eeprom ZTE-A36_eeprom-complete_20100826-172820.B1E.bin Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0098:0096 Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: NET-P108A8FM G B01-EnEs-VE02 g3dBV2.0 Apr 27 2009 16 39 31 09.03 Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-static_20100827-034806.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-security_20100827-034807.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-complete_20100827-034814.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Eeprom Writing: Eeprom repair write error [007F0000:0800]... error: write failed[007F0000] Write Failed Finished, time used: 35 sec Remove/Install battery now ! |
08-27-2010, 08:57 | #6 (permalink) |
Member: 594580 Status: Offline Thanks Meter: 157 | And it is happening when i try to flash firmware.. COM4 [VCP0] selected module v1.78 Device: ZTE-A36 Checking data, wait... Action: write flash write: Firmware ZTE-A36G+_MOVILNET-P108A8FM(G)B01-EnEs-VE02_Apr-27-2009_Movilnet-Venezuela.B1M.bin skip: FFS-1/Customization skip: Language Pack skip: Graphics Pack skip: FFS-2/File system write: Eeprom ZTE-A36_eeprom-complete_20100826-172820.B1E.bin Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0098:0096 Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: NET-P108A8FM G B01-EnEs-VE02 g3dBV2.0 Apr 27 2009 16 39 31 09.03 Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-static_20100827-035608.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-security_20100827-035609.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-complete_20100827-035615.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware error: erase failed: 00800000 Write Failed Finished, time used: 52 sec Remove/Install battery now ! |
08-27-2010, 12:46 | #7 (permalink) | |
Super Moderator Join Date: Jul 2008 Location: Villa del rosario/Nsd Colombia
Member: 813309 Status: Offline Thanks Meter: 1,912 | Quote:
You Use= ZTE-A36G+_MOVILNET-P108A8FM(G)B01-EnEs-VE02_Apr-27-2009_Movilnet-Venezuela.B1M.bin This Is Only For Zte A36g+ | |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
