zte a66 can't unlock zte a66 can't unlock sp-unlock #2 log => module version: v.1.73 => operation (3) started: COM11 ==> get_dll_version dll version: 38.0i ==> set_com_port ==> set_baud_rate ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 357941027737992 ==> get_sw_version sw ver: EA-SD-ZAIN-P108A17V1.0.0B03 ==> get_sec_version sec ver: 00.30Et(4242) ==> get_eep_version eep version: 000B ==> get_eep_revision eep revision: 0000 ==> reading... access result: 00 access level: 00 code verification result: 05 access result: 00 access level: 00 This model can not be unlocked yet last error: No errors => operation finished Please, send operation.log file to support Include in your mail phone name and full text from phone back label DO NOT run this test many times, it's enough to read information only once ! ==> close_com_port sp unlock Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 20FA:8000 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... loading data... error: source buffer too small: 00000000 instead of 0000000A reading eeprom-security... reading eeprom-complete... reading additional data... error: can't read lock-area backup critical area Failed Finished, time used: 1 min 52 sec Remove/Install battery now ! http://forum.gsmhosting.com/vbb/4100497-post45.html |
Zte a66 unlock done by infinity box bro do this: in infinty box chose pana module. and in settings chose ZTE-A66 820013. after that chose unlock method-1. then press unlock without press power button; just insert battery wait for phonne start bout before press power button and wait for infinty to unlock your phonne in 38 second. here is my log: COM10 [VCP0] selected module v1.73 Device: ZTE-A66 820013 Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820013 loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: AIN-P108A17B01-EnFr-GA01 g3dBV2.0 04.12.00 18.26.11 08.02.00 Jun Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A66 820013_eeprom-static_20120223-123320.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A66 820013_eeprom-security_20120223-123321.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A66 820013_eeprom-complete_20120223-123322.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A66 820013_lock-area_20120223-123326.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 45 sec Remove/Install battery now ! |
thanx phone is hard problem |
