12-08-2008, 18:51 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, How to write flash: 1. connect cable 2. run "Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to unlock: 1. connect cable 2. run "Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs: 1. connect cable 2. run "Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software |
12-09-2008, 09:24 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, 1. try to use ordinary COM port cable (not box RJ45 cable) 2. try to select other models from list and try to boot phone (read flash). Let's find model that can boot your phone. 3. post here PCB photo, we will try to find the difference in different A66 types (if it's exist) |
Zte A66 possible unlock with infinity ? | abote didier | Infinity-Box | 21 | 06-19-2011 09:31 |
i can't unlock ZTE A61 by infinity box | shetos17 | Infinity-Box | 7 | 05-27-2010 10:17 |
zte a66 readed bin | sabbalde | SAGEM JTAG UNLOCKER | 1 | 04-01-2010 17:33 |
i can't unlock ZTE A61 by infinity box | shetos17 | Infinity-Box | 1 | 09-28-2009 17:24 |
Zte a66 no proof of unlock via infinity | GAZZUZZ | Infinity-Box | 15 | 01-29-2009 10:31 |
