01-09-2009, 16:46 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | How to write flash (upgrade/downgrade firmware, change language): 1. connect cable 2. run "Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable 2. run "Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not wrks try to make "complete" format (if this option exist) 1. connect cable 2. run "Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software |
zte a66 readed bin | sabbalde | SAGEM JTAG UNLOCKER | 1 | 04-01-2010 17:33 |
zte a 301 ( e-gold: 820013) unlocked as ZTE-A66 820013 | gsmbac | Infinity-Box | 0 | 11-10-2009 08:44 |
ZTE-A66+ & VODAFONE 136 locked | cllins | Infinity-Box | 14 | 11-09-2009 15:49 |
ZTE-A66+ locked | cllins | Infinity-Box | 5 | 10-02-2009 16:27 |
ZTE-A66+ locked | cllins | VSZ Service Tools | 1 | 09-10-2009 07:00 |
