03-21-2009, 10:29 | #1 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 655817 Status: Offline Thanks Meter: 47 | ZTE A68 unlock done........ pin-out: Cable name: ZTE-225/ZTE-A68 keyboard top 1..........8 1: phone Tx (RJ-45 pin-3) 2: phone Rx (RJ-45 pin-2) 3: Gnd logs: COM3 [VCP0] selected module v1.62 Device: ZTE-A68 Checking data, wait... Action: unlock unlock method-1 Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: NGE-P108A5V1.0.0B02 ORANGE-P108A5B01-EnFr-MG02 g3dBV2.0 Apr 23 2 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A68_eeprom-static_20090321-171608.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A68_eeprom-security_20090321-171609.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A68_eeprom-complete_20090321-171615.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A68_lock-area_20090321-171635.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 65 sec Remove/Install battery now ! |
The Following User Says Thank You to anz76 For This Useful Post: |
03-21-2009, 18:30 | #2 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
pls help zte A68 unlock | kifua | Infinity-Box | 3 | 04-18-2009 20:22 |
ZTE A68?? Unlockable? | zakiyyboss | Infinity-Box | 8 | 02-19-2009 18:24 |
@InfinitySupport: ZTE-A136(ZONG) Unlock Done | yawarniazi | Infinity-Box | 143 | 02-03-2009 12:45 |
zte A36 unlock done but still locked | tolski | Infinity-Box | 8 | 05-29-2008 14:57 |
vodafone zte 225 unlock done | vodafone_banha | FuriousGold | 7 | 02-24-2008 21:49 |
