03-21-2018, 09:16 | #1 (permalink) |
Freak Poster Join Date: Jul 2017
Member: 2739340 Status: Offline Thanks Meter: 74 | .::TECNO K8 SPARK PRO HIOS And7.0 PHANTOM BLACK FRP REMOVE::. YES YES IT'S DONE THANK YOU INFINITY AND FILE FOR GRACY_ELEC Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.2017/12/28.11:39_396299 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 470001154D4236585EE6034291D65907 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB6X [eMMC] : FLASH_CID : 150100475836424D4203E65E0759B491 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xFD096D45686C5E86FE283FE887294A96 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! SECURITY : IMEI_SW [1] : 91XXXXXXXXXXXX IMEI_SW [2] : 91XXXXXXXXXXXX BTMAC Addr : C4XXXXXXXXX WiFi MAC : C4XXXXXXX Done! Elapsed: 00:00:13 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.2017/12/28.11:39_396299 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 470001154D4236585EE6034291D65907 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB6X [eMMC] : FLASH_CID : 150100475836424D4203E65E0759B491 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xFD096D45686C5E86FE283FE887294A96 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
The Following 6 Users Say Thank You to Oppo_Tool For This Useful Post: |
03-21-2018, 12:58 | #6 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | HELLO @tyno,@Yusuf Lawal,@Southsider2009 DA FILE WILL COME SOON ON SUPPORT NOW ONLY I HAVE UPLOAD ON SUPPORT GOOD LUCK |
The Following 7 Users Say Thank You to gracy_elec For This Useful Post: |
03-22-2018, 10:48 | #8 (permalink) | |
Junior Member Join Date: Dec 2011
Member: 1704851 Status: Offline Sonork: +265 Thanks Meter: 0 | Quote:
