03-28-2017, 16:44 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: MX-KEY is the BEST NOKIA TOOL Age: 50
Member: 116314 Status: Offline Thanks Meter: 147 | zte blade a475 imei invalid but software logs shows the origional imei tried to repair it by cm2 , still invalid. please help with. Code: Card found : S/N : D87EAC71 , v0135 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D53323779C60042BB1B6E90 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D4200C679906EC2BB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xA0289863AEBA54FB77C60C0E743CDA8A INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : ZTE ProdName : ZTE_Blade_A475 ProdModel : Blade A475 Device : ZTE_Blade_A475 AndroidVer: 5.1 MTKxCPU : MT6735 MTKxPRJ : A475_MXIusacell_1.00 SECURITY : IMEI_SW [1] : 8669170233xxxxx BTMAC Addr : 90C7D81063B3 WiFi MAC : 90C7D8962133 MODEM : BaseBand : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V8_P16_1_lwg_n EXTRA : LCD : Not info available :( LCD Res : 1280x720 TOUCH [0] : GT1XX CAM [0] : gc2355_mipi_raw CAM [1] : a5142_mipi_raw CAM [2] : t4ka3_mipi_raw CAM [3] : s5k5e2ya_mipi_raw MODEM : aeon_fdd_GSM4_W25_LTE2_4_5_7_17 LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR ar_EG pt_PT Done! Elapsed: 00:00:12 Reconnect Power/Cable! Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D53323779C60042BB1B6E90 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D4200C679906EC2BB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xA0289863AEBA54FB77C60C0E743CDA8A INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 8669170233xxxxx Set IMEI [00] : 8669170233xxxxx Prepare finished. Security check required! Wait for phone... Phone found! [ 4 ] Sync... Repair done! Done! Elapsed: 00:00:39 Reconnect Power/Cable! |
10-14-2017, 05:19 | #3 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2113177 Status: Offline Thanks Meter: 5 | NVRAM Retored by NckDongle Exe version: NCKDongle AndroidMTK 2.5.8.1 Selected phone: Blade A475 Action: Restore NVRAM Meta Mode Scanning for presents meta ports... Phone must be off with battery inside. Please insert USB cable now... In some phones need to keep VOL- button untill inserting USB cable. [40]Detected: MediaTek PreLoader USB VCOM (Android) (COM40) \\?\usb#vid_0e8d&pid_2000#5&2085ee92&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [41]META Port Detected: MediaTek USB VCOM (Android) (COM41) USB\VID_0E8D&PID_2007\5&2085EE92&0&1 Start sync target, waiting responce..... Starting META using port[COM41], wait... Brand: ZTE Board: unknown Model: Blade A475 Name: ZTE_Blade_A475 Release: A475_DOMOrange_1.02 Version: 5.1 Platform: MT6735 Using Algo 2. Using Algo 2. Start nvram restore, do not disconnect phone!!!!. NVRAM Retored OK. All done. |
