-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   ZTE Blade L110 (8G) FRP remove problem (http://forum.gsmhosting.com/vbb/f296/zte-blade-l110-8g-frp-remove-problem-2617096/)
debeliamark 06-07-2019 12:04
The phone is stupid ZTE Blade L110 (8G) and seem is supported by SPD module.
6/6/2019 / 7:49:50 PM
Card found: S/N : 0714xxx4 , v0137
Chinese Miracle II  [SPD module] v 1.27
Set mode to : [AltLDR] SP [SC773x] eMMC [Generic 4.x-5.0]
Start  at : [6/6/2019 / 7:52:52 PM]
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
 -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
 ====  Wait for phone...
Phone found! [ 100 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
Boot failed!
DS : Loader start failed! Wrong Model selection!
Boot failed!
Reconnect Power/Cable!
Finish at : [6/6/2019 / 7:56:33 PM]
Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0]
Start  at : [6/6/2019 / 7:56:49 PM]
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v3 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:33
Finish at : [6/6/2019 / 7:57:23 PM]
But FRP lock remain after start ...
Try to reset it via AOSP keyboard settings or *#*#4636#*#* do not work ... there is possible to reset phone, but no developer options and OEM unlock is not available - so FRP remain.
The flashing to Russian's MTC SMART Start 3 work and phone start WITHOUT FRP, but OEM unlock cannot be set, even Developer options work and OEM unlock exist ...
Flash back to ZTE Blade L100 readout is fine:
6/7/2019 / 12:27:44 PM
Set mode to : SP [SC773x] eMMC [Android 5.x]
Infinity SC Firmware Detected
FW Size : 2228 MiB
Load Ok!
File Info
Created by Infinity-Box (c) Chinese Miracle II (c) 2017
Device Brand  : ZTE
Device Model  : ZTE_BLADE_L110
Device CPU    : sp7731gea_hdr
Device IntName : P731A50_EURO_OPEN
Device Version : 5.1
Device Compile : 8/1/2018 1:02:54 AM
Device Project : DIS_EUR_QB18D_L110V1.0.3
Device ExtInfo : ZTE BLADE L110
Start  at : [6/7/2019 / 12:28:35 PM]
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : SC77xx Infinity Package
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x1A records
PMTManager : PMT Update Ok!
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write FSImage : prodnv.img
Write Data ...
Write Data Ok!
Write CodeData : sc7731g_CP0_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Write CodeData : sc8830g_modem_CP2_WCN_14D_W16.05.1_Release.bin
Write Data ...
Write Data Ok!
Write CodeData : logo_480x800.bin
Write Data ...
Write Data Ok!
Write CodeData : fblogo_480x800.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system.img
Write Data ...
Write Data Ok!
Write FSImage : oem.img
Write Data ...
Write Data Ok!
Erase Block : PERSIST
Erase block ...
Block erase Ok!
Write CodeData : sysinfo.img
Write Data ...
Write Data Ok!
Write FSImage : cache.img
Write Data ...
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Erase Block : MISC
Erase block ...
Block erase Ok!
Write FSImage : userdata.img
Write Data ...
Write Data Ok!
Elapsed: 00:05:40
Finish at : [6/7/2019 / 12:34:35 PM]
Work well - but FRP is back again.
Any hint is welcome.
WBR, DebeliaMark, BG
[email protected] 06-07-2019 12:31
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Reset Ok!
Done!
Elapsed: 00:00:33
FW Size : 2228 MiB
Load Ok!
File Info
Device Brand  : ZTE
======= Flash
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Flashing now
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Erase Block : MISC
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Elapsed: 00:05:40
http://forum.gsmhosting.com/vbb/f296...tures-2616774/
debeliamark 06-11-2019 08:23
2 Attachment(s)
This still is not compatible with device:
Even custom FDL is selected like BIN-s or *.pac:
http://forum.gsmhosting.com/vbb/atta...1&d=1560234100
http://forum.gsmhosting.com/vbb/atta...1&d=1560234105
The SW just freeze or cannot stard FDL ...
Also readout from old tool is incompatible.
debeliamark 06-11-2019 19:06
P.S.
Who care about stupid phones like this one ... I don't ... but anyway FRP is cleared, just to do not make sad a customer with it.
Page generated in 0.17800 seconds with 5 queries
