01-16-2017, 21:54 | #1 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Hatfield Harare Zimbabwe Age: 42
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | ZTE BLADE L110 without (root) NETWORK UNLOCK,FIRMWARE BACKUP ,NV & FRP DONE BY CM2SPD Code: Chinese Miracle II [SPD module] v 1.24 Operation : Check/Read Info [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 61 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : P731A50_ZW_TELECEL Model Brand : ZTE Model Device: ZTE_BLADE_L110 AndrVersion : 5.1 BaseBand CPU: SP7731GEA CompileDate : 8/29/2016 11:02:18 AM Project Ver : TELE_ZW_QB18D_P731A50V1.0.2 Model Ext : ZTE BLADE L110 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:24 Reconnect Power/Cable! Operation : Read FullFlash [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 61 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Prepare Ok! - > Wait phone connected ... Phone found! [ 61 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! - > Wait phone connected ... Phone found! [ 61 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : P731A50_ZW_TELECEL Model Brand : ZTE Model Device: ZTE_BLADE_L110 AndrVersion : 5.1 BaseBand CPU: SP7731GEA Project Ver : TELE_ZW_QB18D_P731A50V1.0.2 Model Ext : ZTE BLADE L110 [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731g_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : sc8830g_modem_CP2_WCN_14D_W16.05.1_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x800.bin [Read Ok] : fblogo_480x800.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : oem.img [Read Ok] : sysinfo.img [Build Ok] : cache.img [Read Ok] : recovery.img [Build Ok] : userdata.img AndroidInfo created Firmware Size : 1873 MiB Saved to : C:\InfinityBox\CM2SPD\Flash\ZTE BLADE L110\SP7731GEA_ZTE_BLADE_L110_5.1_TELE_ZW_QB18D_P731A50V1.0.2_ZTE_BLADE_L110\ Done! Elapsed: 00:17:41 Reconnect Power/Cable! Operation : Read NV [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 61 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Detected eMMC Flash , Structure detect Ok! Read GSM NV Read WCN NV Read Ok , 0x000297F8 Saved to : C:\InfinityBox\CM2SPD\Flash\ZTE BLADE L110\CX_SPDNV.spdnv Elapsed: 00:01:03 Reconnect Power/Cable! Operation : SP Unlock [ v1.24 ] Mode : DirectUnlock 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 61 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Detected eMMC Flash , Structure detect Ok! Checking Structure ... SimLock state : Locked! Unlocking ... Unlock Done! Elapsed: 00:00:22 Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 61 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000006ADF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:23 Reconnect Power/Cable! |
The Following 8 Users Say Thank You to johnmadzeka1 For This Useful Post: |
01-18-2017, 10:27 | #2 (permalink) |
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | ZTE BLADE L110 hang on after root for unlocking with other tool Done by CM2SPD Code: Chinese Miracle II [SPD module] v 1.24 Operation : Check/Read Info [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 61 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : P731A50_ZW_TELECEL Model Brand : ZTE Model Device: ZTE_BLADE_L110 AndrVersion : 5.1 BaseBand CPU: SP7731GEA CompileDate : 6/3/2016 8:38:51 AM Project Ver : TELE_ZW_QB18D_P731A50V1.0.1 Model Ext : ZTE BLADE L110 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:17 Reconnect Power/Cable! Infinity SC Firmware Detected FW Size : 1873 MiB Load Ok! File Info Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : ZTE Device Model : ZTE_BLADE_L110 Device CPU : sp7731gea Device IntName : P731A50_ZW_TELECEL Device Version : 5.1 Device Compile : 8/29/2016 11:02:18 AM Device Project : TELE_ZW_QB18D_P731A50V1.0.2 Device ExtInfo : ZTE BLADE L110 Operation : Flash [ v1.24 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 61 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x1A records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... Write Data Ok! Write CodeData : sc7731g_CP0_modem.bin Write Data ... Write Data Ok! Write CodeData : DSP_DM_Gx.bin Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : sc8830g_modem_CP2_WCN_14D_W16.05.1_Release.bin Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : logo_480x800.bin Write Data ... Write Data Ok! Write CodeData : fblogo_480x800.bin Write Data ... Write Data Ok! Write CodeData : boot.img Write Data ... Write Data Ok! Write FSImage : system.img Write Data ... Write Data Ok! Write FSImage : oem.img Write Data ... Write Data Ok! Erase Block : PERSIST Erase block ... Block erase Ok! Write CodeData : sysinfo.img Write Data ... Write Data Ok! Write FSImage : cache.img Write Data ... Write Data Ok! Write CodeData : recovery.img Write Data ... Write Data Ok! Erase Block : MISC Erase block ... Block erase Ok! Write FSImage : userdata.img Write Data ... Write Data Ok! Elapsed: 00:09:07 Reconnect Power/Cable! |
The Following User Says Thank You to johnmadzeka1 For This Useful Post: |
09-27-2018, 17:18 | #4 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Abidjan,ivory coast
Member: 1272267 Status: Offline Sonork: 100.1667652 Thanks Meter: 408 | Operation : SP Unlock [ v1.27 ] Mode : DirectUnlock 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 28 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Detected eMMC Flash , Structure detect Ok! Checking Structure ... SimLock state : Locked! Unlocking ... Unlock Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
The Following User Says Thank You to Freeboy08 For This Useful Post: |
