07-01-2016, 07:59 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: Rajasthan INDIA
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | Nokia 105 Dual Sim MTK Cpu ( RM-1134 ) Contact Service Solution Helps Thanks & Regards By: Gopal Parmar |
The Following User Says Thank You to Yashbanswara For This Useful Post: |
07-01-2016, 08:38 | #3 (permalink) |
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | i do Make "Read RPL" Give NEXT Step Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 85 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : FBB28EE25AF15906CFF4273ED9620082 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : LAGOS61D.10.01.11.p2 BROM/BL stage done Configure RAMINIT Ok Reading flash now ... Done! Control Block Validation (Security Test) : Code 0x08 : CBR Info is wrong! CBR SN not match with BB SN! Say thanks to some "great chinese tools" for kill your phone If backup not done - phone just a brick RPL Saved to : 355107072698081_MTKx_2nd.mtsec Read Done! Connect phone on selected interface... |
07-01-2016, 17:18 | #5 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
The Following User Says Thank You to Kirumira For This Useful Post: |
07-02-2016, 10:07 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Code: Control Block Validation (Security Test) : Code 0x08 : CBR Info is wrong! CBR SN not match with BB SN! Say thanks to some "great chinese tools" for kill your phone If backup not done - phone just a brick |
07-05-2016, 12:19 | #10 (permalink) |
Freak Poster Join Date: Jun 2013 Location: Zimbabwe, mutare
Member: 1957238 Status: Offline Thanks Meter: 80 | it simply means that the phone was written flash dump by any other Chinese boxes like, miracle, volcano boxes and for that matter infinity best can not repair security area for such phones at the moment maybe. just give back the phone to the customer. |
07-12-2016, 11:37 | #11 (permalink) |
Junior Member Join Date: Feb 2012
Member: 1721782 Status: Offline Thanks Meter: 0 | I would kindly like to ask you for an advice. The mobile phone Nokia 105 does not work and for purposes of forensic analysis I need to dwell the data from the device. (contacts, text messages and so on) Could you please help me with gaining the needed data or send some instruction materials? Thank you. |
