Old 01-28-2010, 16:58   #1 (permalink)
Member: 92317
Sonork: 100.1591991
Thanks Meter: 223
Question zte dead after unlock
and i was traing to flash but no luck
and i have 1 still lock
COM1 [VCP0] selected
module v1.73
Device: ZTE-A35
Checking data, wait...
Action: write flash
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
sw version: ARO-P108A7 Z B01-EnEs-DOM02 g3dBV2.0 ES-DOM-CLARO-P108A7 Z V1.0.
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-static_20100128-113456.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-security_20100128-113456.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-complete_20100128-113458.B1E.bin
backup critical area Done
Check memory ...
Check memory Done
Write ...
Erasing: Firmware
Writing: Firmware
error: write failed[00400000]
Write Failed
Finished, time used: 30 sec
Remove/Install battery now !
Old 01-28-2010, 17:26   #2 (permalink)
Member: 1043909
Thanks Meter: 51,406
Hi,
did you checked battery voltage ? it may be that battery become empty.
did you tried to use 115200 baudrate ?
Old 01-29-2010, 06:03   #3 (permalink)
Member: 92317
Sonork: 100.1591991
Thanks Meter: 223
same errol batery full extra power suply and nothing yet
module v1.74
Device: ZTE-A35
Action: write flash
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 2001:8000
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-static_20100129-005953.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-security_20100129-005955.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-complete_20100129-010001.B1E.bin
Check memory ...
Check memory Done
Write ...
Erasing: Firmware
error: erase failed: 00400000
Write Failed
Finished, time used: 36 sec
Old 01-29-2010, 06:03   #4 (permalink)
Member: 92317
Sonork: 100.1591991
Thanks Meter: 223
and this one can't be unlock
module v1.74
Device: ZTE-A35
Action: "sp-unlock"
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 2090:8000
Connecting Done
Check hardware ...
Check hardware Done
loading data...
error: source buffer too small: 00000000 instead of 0000000A
reading additional data...
error: can't read lock-area
backup critical area Failed
Finished, time used: 2 min 1 sec
Old 01-29-2010, 06:13   #5 (permalink)
Member: 92317
Sonork: 100.1591991
Thanks Meter: 223
this one is done
module v1.74
Device: ZTE-A35
Action: "sp-unlock"
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
230400
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-static_20100129-010804.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-security_20100129-010805.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-complete_20100129-010809.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_lock-area_20100129-010819.B1E.bin
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 49 sec
but this one still lock
module v1.74
Device: ZTE-A35
Action: "sp-unlock"
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
230400
Set Baud Done
Connecting ...
flash: 2001:8000
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-static_20100129-011006.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-security_20100129-011007.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-complete_20100129-011010.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_lock-area_20100129-011022.B1E.bin
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 59 sec
if u can help me on this i will aprisiet it
Old 01-29-2010, 09:58   #6 (permalink)
Nadjombe's Avatar
Member: 185608
Thanks Meter: 579
Restore phone and unlock again!
Old 01-29-2010, 10:59   #7 (permalink)
Member: 1043909
1. phone with error: write failed[00400000]: if phone can not power-on, try to select model BSNL-200 and flash phone again
2. phone with flash: 2001:8000: it may be that phone hardware is damaged and as a result flash chip can not be written well.
Nokia 2720 dead after unlock unlocklleida Cyclonebox 3 03-31-2010 18:25
help urgently G1157 dead after unlock.. razisamb FuriousGold 4 03-29-2010 16:38
ZTE A62 dead after unlock ayhen42 FuriousGold 5 07-10-2009 07:53
zte 225 dead after unlock ranagaurav Infinity-Box 16 05-08-2009 09:36
ZTE A62 New dead after unlock .:[email protected]==:. FuriousGold 36 11-26-2008 12:12
Page generated in 0.31928 seconds with 8 queries
