08-19-2010, 10:13 | #1 (permalink) |
Product Supporter Join Date: Nov 2008 Location: UnlockBank World
Member: 912688 Status: Offline Sonork: 100.1623116 Thanks Meter: 184 | ZTE G-R830 Connected Ok Action: read/check information Model: Aiko-17G Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E05 Hardware version: E-PK-CMPAK-P103F2V1.0.0B02 Software version: E-PK-CMPAK-P103F2V1. Software date: 2006.06.14 Barcode: 248036900216 10P 10P imei-1: 354744030094390 Finished, time used: 5 sec Remove/Install battery now ! Read Detailed Information COM34 [VCP0] selected module v3.52 Device: Aiko-17G Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:C103:0009 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC227E22632260:2AEA0000000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] type TCL-ID is absent rom info detection finished rom info ver: 04 sw version: ZTENJ25_07A_PMJ_PCB01_GPRS_MT6225_S00.E-PK-CMPAK-P103F2V1_0_0B02.BIN project-id: E-PK-CMPAK-P103F2V1.0.0B02, 00000000 code offset: 00000000 ffs offset/size [01]: 01000000/01000000 rom info structure: 2nd [standard] type TCL-ID is absent ffs/eeprom address assigned: 01000000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... firmware version: ZTENJ25_07A_PMJ_PCB01_GPRS_MT6225_S00.E-PK-CMPAK-P103F2V1_0_0B02.B detecting firmware build... ............................................... firmware build: 1.0.0B02E-PK-CMPAK-P103F2V1.0.0ZTENJ25_07A_PMJ_HW2009-12-0908-40 detecting product-id... .................................................. .................................................. ............................ done detecting languages... ..................................... language parameters detected detected languages: En Finished, time used: 1 min 38 sec Remove/Install battery now ! Read Full Flash COM34 [VCP0] selected module v3.52 Device: Aiko-17G Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:C103:0009 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC227E22632260:2AEA0000000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] type TCL-ID is absent rom info detection finished rom info ver: 04 sw version: ZTENJ25_07A_PMJ_PCB01_GPRS_MT6225_S00.E-PK-CMPAK-P103F2V1_0_0B02.BIN project-id: E-PK-CMPAK-P103F2V1.0.0B02, 00000000 code offset: 00000000 ffs offset/size [01]: 01000000/01000000 rom info structure: 2nd [standard] type TCL-ID is absent ffs/eeprom address assigned: 01000000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Aiko-17G_ZTENJ25_07A_PMJ_PCB01_GPRS_MT6225_S00.E-PK-CMPAK-P103F2V1_0_0B02__fullflash_part_1_of_1... file saved: F:\Box Installed\InfinityBox\MModule\Aiko-17G_ZTENJ25_07A_PMJ_PCB01_GPRS_MT6225_S00.E-PK-CMPAK-P103F2V1_0_0B02__fullflash_part_1_of_1_20100819-125012.B0M.bin Finished, time used: 7 min 32 sec Remove/Install battery now ! I used ZTE 225 Cables [IMG]http://www.************/forum/uploads/monthly_05_2010/post-92661-1273263671.jpg[/IMG] |
The Following User Says Thank You to GSM HABIBI For This Useful Post: |
08-20-2010, 14:04 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Please, run ChineseMiracle software, select model "NAND" and read full flash from this phone. Please, send full flash backup (or link) to [email protected] Thank you ! |
08-21-2010, 11:02 | #3 (permalink) |
Member: 912688 Status: Offline Sonork: 100.1623116 Thanks Meter: 184 | Sir I dont have mobile now in my hand but I have read full flash with MModule.exe here is full flash file http://rapidshare.com/files/41422042...odule.zip.html Last edited by GSM HABIBI; 08-21-2010 at 11:12. |
08-22-2010, 12:32 | #5 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Thanks for file, but it was read only 25% of required data. We need to get full flash backup from this phone to make support for it. If somebody has this phone on hands: Please, run ChineseMiracle software, select model "NAND" and read full flash from this phone. Please, send full flash backup (or link) to [email protected] Thank you ! |
Connecting Dejan Flasher to Nokia 61xx | gsmxc | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 01-07-2001 22:09 |
Connecting To Phone | jscoulter | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-20-2000 11:03 |
How to use Nokia tool - with connection 6-7 pin or not?.. | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-20-2000 19:53 |
WE OFFER cables for connection cellular-phones to the computers | GLEBUS | Main Sales Section | 0 | 06-04-2000 19:05 |
Nokia Datasuite Connection Failure | Judesp | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-27-1999 09:36 |
