ZTE - G S202 pinouts i can not find pinouts for this model there is micro USB connector for charging/USB SW says solder pins on board but no picture available? any idea? wbr,A |
I think it's need to open phone and Rx/Tx/Gnd test points should be marked at phone PCB. If you will make this operation, please, make a phone PCB photo and send picture to [email protected] so we will be able to update our pinout database. Thank you ! |
tnx on PCS in NO marks i did manage to cennect & read & unlock phone photos, files are in your mailbox wbr,A |
COM14 [VCP0] selected module v3.82 Action: "sp-unlock" unlock method: smart fast Model: ZTE-S202 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:630D:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: SPA-ORANGE-P109A13V1.0.1B01 Version: ZTENJ23D_08B_HW ==================== New firmware found (v.3.82, database date: 04.04.2011): SPA-ORANGE-P109A13V1.0.1B01 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 80 byte(s) read imei: 35805103165345 connection Ok 116 byte(s) read reading data... reading data #2... building new data... writing data... 115 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 2 min 4 sec Remove/Install battery now ! especial thnx to HOST-MEDIA - Nador Man :D BR,Douhal |
CAN U PLS POST THE PINOUTS WBR sahil2000ind |
full flash.. and eeprom...and firmware Reading... BR,Douhal |
GENERAL INFORMATION Action: read/check information Model: ZTE-S202 Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6223, E05 Hardware version: ZTENJ23D_08B_HW Software version: SPA-ORANGE-P109A13V1 Software date: 2000.00.00 Barcode: 253293806049 10P imei-1: 358051031653455 Finished, time used: 15 sec Remove/Install battery now ! DETAILED INFORMATION COM14 [VCP0] selected module v3.82 Device: ZTE-S202 Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:630D:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent ==================== New firmware found (v.3.82, database date: 04.04.2011): ZTENJ23D_08B_PCB01_GSM_MT6223_S00.SPA-ORANGE-P109A13V1_0_1B01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 05 sw version: ZTENJ23D_08B_PCB01_GSM_MT6223_S00.SPA-ORANGE-P109A13V1_0_1B01.BIN project-id: SPA-ORANGE-P109A13V1.0.1B01, 00000000 code offset: 00000000 ffs offset/size [01]: 00700000/00100000 rom info structure: [standard] type (05) TCL-ID is absent ffs/eeprom address assigned: 00700000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... firmware version: ZTENJ23D_08B_PCB01_GSM_MT6223_S00.SPA-ORANGE-P109A13V1_0_1B01.BIN detecting firmware build... ............... firmware date/time: 2010-10-14 14-42 hw1: ZTENJ23D_08B_HW hw2: 08B_ZTENJ23D_08B done detecting product-id... ................................ done detecting languages... .............. language parameters detected detected languages: En Es Finished, time used: 1 min 5 sec Remove/Install battery now ! BR,Douhal |
Can someone give pinout here? or what cable should be used? Via micro-usb connector or via headphone jack? |
YES NO JPG FILE FOUND IN PINOUT PLS UPDATE THE CABLE DATABASE WBR sahil2000ind |
Code: COM2 [VCP0] selected |
thanks.......................... |
