Old 05-12-2011, 12:14   #1 (permalink)
Member: 488536
Thanks Meter: 35
zte-G x670 after unlock not power on
dear br, zte-G x670 after unlock not power on pls help me,,,,,,,,,,
pls give this flash file link br,,,,,,,,,,
COM3 [VCP0] selected
module v3.82
Device: ZTE-Sage
Checking data, wait...
Action: reset settings ("format ffs")
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:6D03:0005
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC227E22632260:18E59F00000000
flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb
otp offset: 00000000
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [protected] type (07), 1 record(s)
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\InfinityBox\MModule\backup_security\id.CB118A8C .[ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670_V1_O G_Z2_FRES_DFFA116.BIN_0F9E0AAE].rpl
New firmware found (v.3.82, database date: 04.04.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
device-id: CB118A8C
rom info ver: 07
sw version: ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670_V1_O G_Z2_FRES_DFFA116.BIN
project-id: X670_V1_OG_Z2_FRES_DFFA116, AE0A9E0F
code offset: 00000000
ffs offset/size [02]: 01000000/01000000
TCL-ID is absent
ffs/eeprom address assigned: 01000000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: ZTE-Sage_ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670 _V1_OG_Z2_FRES_DFFA116__ffs...
file saved: C:\InfinityBox\MModule\ZTE-Sage_ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670 _V1_OG_Z2_FRES_DFFA116__ffs_20110512-105119.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\InfinityBox\MModule\backup_security\ZTE-Sage_ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670 _V1_OG_Z2_FRES_DFFA116__system_log_CB118A8C_0F9E0A AE_20110512-105152.B0X.bin
Finished, time used: 8 min 31 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 05-12-2011, 18:25   #2 (permalink)
Member: 148515
Thanks Meter: 14,899
hello!
load this file: ZTE-Sage_ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670 _V1_OG_Z2_FRES_DFFA116__ffs...
this file is saved here: C:\InfinityBox\MModule\ZTE-Sage_ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670 _V1_OG_Z2_FRES_DFFA116__ffs_20110512-105119.B0E.bin
as EEPROM and write it back to you phone. This is your EEPROM backup.
after you restore your phone to original state- make unlock selecting CORRECT phone model
Old 05-13-2011, 00:12   #3 (permalink)
Member: 1043909
Thanks Meter: 51,303
module v3.82
Device: ZTE-Sage
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
status: FF
Boot Done
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is absent
device-id: CB118A8C
rom info ver: 07
TCL-ID is absent
====> Write ...
Write Done
ffs formatting...
Finalization Done
what "unlock" you talk about ?
what you have tried to do with phone exactly ?
waiting for HONEST answer !
Old 05-13-2011, 02:38   #4 (permalink)
Member: 488536
Thanks Meter: 35
same problem br,,,,,,,,,,,,
module v3.82
Device: ZTE-Sage
Action: write flash
"smart write" active
skip: Firmware
skip: Customization/Language Pack
skip: Customization
write: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
status: FF
Boot Done
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is absent
startup code area #1 record #1 is damaged, recalculation required
device-id: CB118A8C
rom info ver: 07
sw version: ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670_V1_O G_Z2_FRES_DFFA111.BIN
project-id: X670_V1_OG_Z2_FRES_DFFA111, 09457FC0
TCL-ID is absent
reading: Aiko-17G_ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670_ V1_OG_Z2_FRES_DFFA111__ffs...
file saved: C:\InfinityBox\MModule\Aiko-17G_ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670_ V1_OG_Z2_FRES_DFFA111__ffs_20110513-054745.B0E.bin
====> Write ...
Area: Eeprom/ffs
Write: Eeprom/ffs
sec info (fast) detection...
Write Done
Finalization Done
Finished, time used: 8 min 49 sec
first time i default unlock method no succes, after second time i change unlock method ,
standard fast and sp-unlock thats all ,now phone not power pls any idea br,,,,,,,,,,,,
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 09:14
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 21:09
Page generated in 0.25622 seconds with 8 queries
