11-23-2009, 11:03 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Dar es Salaam TANZANIA
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | Vodafone-135 boot with 235 any sln module v2.94 Action: unlock unlock method: smart fast Model: Vodafone-235 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:57F5:A00C status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: BM32A1.V2.14.M00.02.14 Version: FOXLINK23D_08A_HW 80 byte(s) read imei: 35412403183275 connection Ok 186 byte(s) read reading data... |
11-23-2009, 11:07 | #2 (permalink) |
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | COM3 [VCP0] selected module v2.94 Action: unlock unlock method: smart fast Model: ZTE-X760 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:57F5:A00C status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: BM32A1.V2.14.M00.02.14 Version: FOXLINK23D_08A_HW 44 byte(s) read connection Ok 157 byte(s) read reading data... reading data #2... reading data #3... reading data #4... reading data #5... WARNING ! Unknown lock structure ! Read flash and send to support: [email protected] error: operation failed ! Finished, time used: 21 sec Remove/Install battery now ! COM3 [VCP0] selected module v2.94 Device: ZTE-X760 Checking data, wait... advanced flash detection enabled Action: read NOR flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:57F5:A00C status: 01 boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 8 sec Remove/Install battery now ! |
11-23-2009, 15:21 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, read full flash from this phone with Infinity-Box ChineseMiracle software (like MT6205 NOR model) and send full flash backup to [email protected] so we will be able to make support for this model. Also, what is this phone pinout ? |
11-23-2009, 15:38 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: .:Islam:.:Peace:.Pakistan:. Age: 48
Member: 266874 Status: Offline Sonork: 100.1581444 Thanks Meter: 97 | successfully unlocked Phone & differences between. unlock method: smart fast Model: ZTE-X760 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:7A03:0000 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: X760_Z15UK_FS_BFFA110 Version: ZTEMT25_07A_HW_D 44 byte(s) read imei: 35235302569154 connection Ok 157 byte(s) read reading data... reading data #2... building new data... writing data... 145 byte(s) read reading data... building new data... writing data... verifying... verification Ok done Finished, time used: 14 sec Remove/Install battery now ! and other one not unlocked log from above. COM3 [VCP0] selected module v2.94 Action: unlock unlock method: smart fast Model: ZTE-X760 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:57F5:A00C status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: BM32A1.V2.14.M00.02.14 Version: FOXLINK23D_08A_HW 44 byte(s) read connection Ok 157 byte(s) read reading data... reading data #2... reading data #3... reading data #4... reading data #5... WARNING ! Unknown lock structure ! Read flash and send to support: [email protected] error: operation failed ! Finished, time used: 21 sec Remove/Install battery now ! Am i Right? |
11-23-2009, 16:56 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If you want to see your phone unlocked but NOT DAMAGED I strongly suggest you to stop your own tests but follow this easy instruction: http://forum.gsmhosting.com/vbb/show...15&postcount=3 |
11-24-2009, 09:35 | #6 (permalink) |
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | Hello, Please, read full flash from this phone with Infinity-Box ChineseMiracle software (like MT6205 NOR model) and send full flash backup to [email protected] so we will be able to make support for this model. Also, what is this phone pinout ? +++================= the pin out i use Zte 125 pinout the problem is reading flash , it could not respond on reading , only stop on the way but anyway i will try another method, i know your team is working very faster |
11-29-2009, 03:50 | #7 (permalink) |
No Life Poster Join Date: Feb 2003 Location: EAST AFRICA! TANZANIA
Member: 22893 Status: Offline Sonork: 100.1607086 Thanks Meter: 131 | @InfinitySupport Please, read full flash from this phone with Infinity-Box ChineseMiracle software (like MT6205 NOR model) and send full flash backup to [email protected] so we will be able to make support for this model. screen shot on whathapen when read, http://forum.gsmhosting.com/vbb/show...t=VODAFONE+135 |
11-30-2009, 11:42 | #8 (permalink) | |
https://forum.gsmhosting.com/vbb/f296/unlock-vodafone-135-failure-867597/ | |
Vodafone 135 unlocked by infinity | ericnite101 | Infinity-Box | 10 | 08-03-2010 11:12 |
Vodafone 135 | xtream 08 | SAGEM JTAG UNLOCKER | 1 | 01-23-2010 21:37 |
Vodafone 135 | xtream 08 | Infinity-Box | 3 | 01-23-2010 19:08 |
unlock vodafone 135 failure | mkwatis | Infinity-Box | 4 | 12-18-2009 12:48 |
kp 135 can't boot with infinity | agadir5241 | Infinity-Box | 2 | 12-23-2008 21:32 |
