01-19-2010, 08:55 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: punjab
Member: 271008 Status: Offline Thanks Meter: 280 | zte gx 761 after unlock still on np code Device: ZTE-X761 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:9703:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22312200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.4B358 AE5.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA1 06.BIN_5DD3CF59].rpl rom info detection finished device-id: 4B358AE5 rom info ver: 04 sw version: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA1 06.BIN project-id: X761_Z2_SF_BFFA106, 59CFD35D code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 00E00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA106__ffs... file saved: C:\Program Files\InfinityBox\MModule\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA106__ffs_20100119-132119.B0E.bin flash: 01227E22312200:18E59F00000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ......................... required data found flash: 01227E22312200:18E59F00000000 flash: 01227E22312200:18E59F00000000 Write: area 1 (pass 1) ....................................... area 1 patch applied Ok Special operation Done ====> Write ... flash: 01227E22312200:18E59F00000000 Write: ffs Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA106__system_log_4B358AE5_5DD3CF59_20100119-132210.B0X.bin Finished, time used: 3 min 19 sec Remove/Install battery n |
The Following User Says Thank You to neeraj1st For This Useful Post: |
01-20-2010, 14:30 | #3 (permalink) |
Member: 271008 Status: Offline Thanks Meter: 280 | i try to unlock with smart fast mode i try to unlock with smart fast mode but software did not complete the action and said try to formate ur handset and then try again i formate my handset my handset become dead did not power up , i flash it again with same files but nothing happen wt to do? |
01-20-2010, 16:38 | #4 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: TUNISIA Age: 41
Member: 479816 Status: Offline Thanks Meter: 851 | Quote:
restore this backup :file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA106__system_log_4B358AE5_5DD3CF59_20100119-132210.B0X.bin | |
01-21-2010, 22:51 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Try to unlock phone with latest software MModule_v3.03 with "smart fast" unlock method. In case of any problems post here operation log. |
01-24-2010, 11:04 | #6 (permalink) |
Major Poster Join Date: Jun 2006
Member: 296122 Status: Offline Thanks Meter: 4 | COM44 [VCP0] selected module v3.03 Action: "sp-unlock" unlock method: smart fast Model: ZTE-X761 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:EC03:0002 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: X761_Z2_SF_BFFA108 Version: ZTEMT25_07A_HW_C 44 byte(s) read imei: 35787302323835 connection Ok 157 byte(s) read reading data... reading data #2... building new data... writing data... 145 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... error: verification failed what to do: 1. be sure that you have full flash backup for emergency case 2. make "format ffs" in "complete" mode 3. power-on phone 4. power-off phone by "Power" button (DO NOT remove battery) 5. repeat current operation error: operation failed ! Finished, time used: 18 sec Remove/Install battery now ! |
01-25-2010, 15:31 | #7 (permalink) | |
what to do: 1. be sure that you have full flash backup for emergency case 2. make "format ffs" in "complete" mode 3. power-on phone 4. power-off phone by "Power" button (DO NOT remove battery) 5. repeat current operation | |
01-25-2010, 16:41 | #8 (permalink) |
Member: 271008 Status: Offline Thanks Meter: 280 | don"t make complete formate ur handset it will kill ur handset as mine , now my handset did not power on with same flash file what to do i don"t understand |
01-25-2010, 17:59 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | flash phone with this firmware from support area: ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA106_En_Fr_Es_Vodafone-Indie.B0M.bin phone will be alive for sure |
01-26-2010, 08:28 | #12 (permalink) |
Member: 271008 Status: Offline Thanks Meter: 280 | i flashed with same file my handset did not power on here is the logVCP1] selected module v3.03 Device: ZTE-X761 Checking data, wait... advanced flash detection enabled Action: write flash write: Firmware ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00[1].X761_Z2_SF_BFFA106_En_Fr_Es_Vodafone-Indie.B0M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs ZTE-X761_ffs_04[1].X761_Z2_SF_BFFA108.B0E.bin ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:9703:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22312200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.4B358 AE5.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA1 06.BIN_5DD3CF59].rpl rom info detection finished device-id: 4B358AE5 rom info ver: 04 sw version: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA1 06.BIN project-id: X761_Z2_SF_BFFA106, 59CFD35D code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA106__ffs... file saved: C:\Program Files\InfinityBox\MModule\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA106__ffs_20100126-123309.B0E.bin Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA106__system_log_4B358AE5_5DD3CF59_20100126-123356.B0X.bin Area: Firmware flash: 01227E22312200:18E59F00000000 Write: Firmware Area: Eeprom/ffs flash: 01227E22312200:18E59F00000000 Write: Eeprom/ffs sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA106__system_log_4B358AE5_5DD3CF59_20100126-124623.B0X.bin Finished, time used: 15 min 42 sec Remove/Install battery now ! i flashed with other files some time my handset show only startup logo then show white screen only, two days ago my handset dead when i try to flash it with some other files, then i flashed with above files and my handset become power on and when i try to unlock it with smart fast mode the sofware ask me to complete formate and i did that this made my handset become dead, i again trying to flash with same files but this time my handset did not power on why????????? Last edited by neeraj1st; 01-26-2010 at 08:36. |
01-26-2010, 10:05 | #13 (permalink) |
Member: 271008 Status: Offline Thanks Meter: 280 | now i flashed with these flash files now my handset power on normally but after its come on blinking wats to do here is the log module v3.03 Device: ZTE-X761 Checking data, wait... advanced flash detection enabled Action: write flash write: Firmware ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00[1].X761_Z2_SF_BFFA108_En_Fr_Es.B0M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs ZTE-X761_ffs_06[1].X761_Z2_SF_BFFA108.B0E.bin ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:9703:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22312200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.4B358 AE5.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA1 06.BIN_5DD3CF59].rpl rom info detection finished device-id: 4B358AE5 rom info ver: 04 sw version: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA1 06.BIN project-id: X761_Z2_SF_BFFA106, 59CFD35D code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA106__ffs... file saved: C:\Program Files\InfinityBox\MModule\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA106__ffs_20100126-134535.B0E.bin Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA106__system_log_4B358AE5_5DD3CF59_20100126-134542.B0X.bin Area: Firmware flash: 01227E22312200:18E59F00000000 Write: Firmware Area: Eeprom/ffs flash: 01227E22312200:18E59F00000000 Write: Eeprom/ffs sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA106__system_log_4B358AE5_5DD3CF59_20100126-135732.B0X.bin Finished, time used: 14 min 23 sec Remove/Install battery now ! |
01-26-2010, 19:03 | #14 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | as I can see from your first log your phone had firmware ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA106 what to do now: 1. flash phone with ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA106_En_Fr_Es_Vodafone-Indie.B0M.bin 2. flash phone with C:\Program Files\InfinityBox\MModule\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA106__ffs_20100119-132119.B0E.bin CHARGE BATTERY completely with external power supply |
01-30-2010, 13:43 | #15 (permalink) | |
Member: 271008 Status: Offline Thanks Meter: 280 | sir with this file my handset did not power on Quote:
zte gx 761 dead while flashing | neeraj1st | Infinity-Box | 24 | 02-25-2012 11:19 |
zte gx 761 dead after complete formate | neeraj1st | Infinity-Box | 5 | 08-20-2010 16:11 |
Coral 640 unlocked but still asking NP codes.. . | lester_oh | Infinity-Box | 32 | 07-26-2010 09:52 |
ZTE GX-761 vodafone spain unlock probleme [ANSWERED] | yassinek85 | PolarBox 3 | 3 | 03-16-2010 23:19 |
After Unlocking still asks Subsidy code...C116. | harim_1981 | Infinity-Box | 1 | 07-24-2008 22:04 |
